Question about Homedics Health & Beauty
Homedic variable speed massager
Speed intermittently goes to full speed no matter what the slide position is
Posted by R Stone on
  • R Stone
    R Stone Jun 27, 2019
    Yes, that makes sense. The board is quite simple with all inexpensive components. I used some cleaner on the sliding pot with no effect. Perhaps the triac is the most likely culprit?
5 Related Answers
joboo1
Jim London
  • 257 Answers
SOURCE: Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Posted on Mar 02, 2009
Anonymous
  • 154 Answers
SOURCE: Variable Speed Control is faulty
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
Posted on Apr 16, 2009
Anonymous
  • 4 Answers
SOURCE: Wiper does not stop wiping until engine shut-off
you need to replace multi function switch
Posted on May 08, 2009
Anonymous
  • 6 Answers
SOURCE: variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
Posted on May 26, 2009
Anonymous
  • 19 Answers
SOURCE: Windshield wiper does not work on INTERMITTENT or
replace the motor.it will stop being goofy after that i promise
Posted on Sep 02, 2009
Kenwood Chef KM001 Service Manual or help with motor speed?
Hi I am also looking for a service manual for KM001.
Please BGR1 can you email me this manual if possible. I am having the same intermittent start problem as this person who asked the question to you.
My email address is [email protected]
Apr 21, 2012 | Food Mixers
Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Dec 16, 2011 | Lionel Cw 80 Transformer
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
Apr 16, 2009 | Dremel Variable - Speed Multipro Rotary...
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Massager question
Applying heat with your massage will enhance the sensation of themassage, for deeper relaxation.
Aug 27, 2008 | Jeanie Rub Variable Speed Personal...
Health & Beauty Logo
60 people viewed this question
Top Homedics Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
