Question about Samsung Audio Players & Recorders
Is there a way to use the RX-V371 with a Samsung Q60R TV?
My uncle just got a samsung Q60r TV and we cant figure out how to get his RX-v371 to work with it. When we hook the cable box through the receiver into the TV the TV can't get a signal from it.
Posted by Jeff Armatis on
3 Related Answers
John Cunningham
  • 6771 Answers
SOURCE: yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Posted on Apr 02, 2012
larry984
larry984
SOURCE: Just bought a Yamaha RX-V371
I found a fix for this that worked for me. Dont ask why I tried it but it worked! I put a HDMI switcher between the cablebox and the yamaha HDMI input. I am not sure why it works but it does. The audio was actually clearer and the center channel responded better. An hdmi switch is about $25. Good Luck!
Posted on Nov 02, 2012
Lissa Wied
  • 344 Answers
SOURCE: yamaha rx-v371 comcast remote codes DO NOT WORK!
Yes it will not work , Your just wasting your time trying,
Posted on Nov 29, 2012
Why won't it turn on?
may be locked in protect mode. Try holding 'tone control' and 'info' buttons and pressing power
I have a yamaha receiver rx-v371 the speaker imput clamps on the back are broken. Can i use banana plugs?
For the main speakers , Yes, you can use banana plugs. Theyre built for that.
I hope that helps
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
if you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Yamaha rx-v371 comcast remote codes DO NOT WORK!
1helpful
2answers
Yamaha rx-v371 shuts off 2 secs after turning on
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
