Question about Photography
I have bought selfie stick tripod x10, and I can't secure legs to stay firm? Can I see your video instruction.
Posted by Tony Vrzina on
5 Related Answers
Anonymous
  • 23 Answers
SOURCE: One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
Posted on Jun 07, 2007
MIke
  • 685 Answers
SOURCE: how do i remove the video head from the tripod
Raise the center column all the way up. Under the head next to the center column are at least 2 or 3 screws. Back them out uing a meduim slotted screw driver. The head should then screw off.
Posted on Feb 28, 2010
Anonymous
  • 1340 Answers
SOURCE: I just bought second hand
Third link is Australian site.Here is a link for one in the US.I will look also for something closer to you.It's a start though.
http://www.smarter.com/se--qq-celestron%2Bnexstar%2Btripods.html
Here are some straight from celestron.com
http://www.celestron.com/c3/category.php?CatID=52
Finally!A link to tripods in Australia.
http://shopping.ninemsn.com.au/results/camera-tripods/bcatid1037/forsale?text=category:camera-tripods
I was in Perth in the mid 1980's and thought it was beautiful.I was in US Navy.Anyhow,if the last site doesn't work for you,all I did was google tripods in Australia.Probably much cheaper to ship.Good luck and G'day mate!
Posted on Aug 05, 2010
Testimonial: "THANK YOU VERY MUCH FOR YOUR HELP.CHEERS ROB"
Anonymous
  • 48 Answers
SOURCE: Giotto Aluminum Tripod # 9160
Call us at 800 735-4373 regarding serving Giottos tripods and for our address to get this properly repaired. It does not need lubrication.
Posted on Sep 04, 2011
Anonymous
  • 187 Answers
SOURCE: the plastic leg ht clamps
Well if you don't want to return it and it doesn't seem to you like an easy fix, by comparing how the mounting supports are connected on the legs, than you know you have a defective tripod?
There are multiple kinds of support clamps/brackets you can use or...
I would just go purchase a small roll of Automotive Velcro, (thats the toughest and trongest stuff around and cheap at Walmart), to mount to and strap around it, Or you could use a belt, string anything to wrap or tie around it!
Dollor General sells a small box of I believe (8) long strips of Velcro for $2.00 you can attach to some material, (stronger the better) on both ends and strap it cloed that way! That's also pretty good velcro, but really needs to be sewn or safety pinned to the material!
I really don't blame you, I hate having to return things, its a pain, that is for sure! Atleast you don't have the opposite effect of it closing on you! lol You'd have to take it back then!
Kind regards!
Martie
Posted on Sep 15, 2011
I'm looking for the Velbon Videomate 601 instruction manual for my tripod.
Is a manual or instruction leaflet really necessary ? Tripods are actually amazingly simple to use. You spread the three legs (three legs - 'tri'-pod) and place them firmly on level ground. Then you attach the camera, camcorder, spotting scope or whatever to the top, and use the equipment as desired.
1helpful
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
1helpful
I just bought second hand a celestrton nextar 5 se and when i try to extend the tripod one hole leg came off.The seller does not belive me but I think is just a dishonest person because the leg is so loose...
1helpful
Cant git my cst 24x to level up or stay level on 2 points
try making the base as secure to the ground as you can and the wing nuts on the legs firm to eliminate this from the problem. make the base as level as you can with a topedo level and secure the level to the tripod. put all leveling screws in the middle. all adjustments should be minor. go through your leveling sequence and if it wont stay level, you will have to send it off to be recalibrated
Want specifications for titan ii ii-950
Call Ritz Camera at 877-999-RITZ (7489). They "might" be able to assist you. Ritz's generic lenses are Quantaray made by Sigma. I don't know who makes the tripod. They are able to provide documentation for you, but I don't know if they will. Ritz has an online help form that you can fill out on their web site also
The little 'hooks' on the bottom of the legs 'snap' into each other to secure the legs together. Each leg has a 'hook snap' which clicks into place with the other legs. It is merely a way to secure the legs from flopping open. I bought the same tripod, a good solid piece of equipment. No instructions but its easy enough to figure out. Hope this helps.
1helpful
5answers
Samsung LE37R8 Picture in Picture
Sorry, meant to say you need to connect an external source (Video, Pc) then picture in picture will be available. You cant view tv channels via picture in picture
Photography Logo
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
