Question about Stihl Saws
Rebuilt a stihl ts400 new rings,bearings carb electronic module,plug . When I try to start almost pull my hand off. Pulls ok with plug out and still wont pull with plug in and the muffler off
Posted by Chris Dee on
Ian Fowlie
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Sounds like you need to check the valve & ignition timing .
Posted on Jul 11, 2019
5 Related Answers
Hairyloon
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
Chuck Bamforth
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
Anonymous
  • 53 Answers
SOURCE: rebuilt carbs-starts and idles but wont rev up without choke on
sounds like the main jets are partly pluged, you must remve all brass jets and seats including needle jet and its slide soak in carb cleaner and blow out with compressed air only.. hold up to bright light to verify if all are clean. jim
Posted on Mar 29, 2009
Anonymous
SOURCE: stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Posted on Apr 20, 2010
Spud Howell
  • 66 Answers
SOURCE: i fitted a new carb
Are you using new fresh fuel ?
Posted on Feb 08, 2011
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400
check and replace the air filter and fuel filter. Both of these can affect the acceleration.
Jan 15, 2014 | Stihl Saws
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I rebuilt a TS400 and now it doesn't work, please help....
if you havent tuned the carbi try screw the low speed screw gently all the way clock wise onto the seat then turn it back 1 full turn anti clockwise.if then it starts turn the la screw clockwise till the blade starts to run then back it off till the cut disc stops turning a simple tune done
Jul 14, 2012 | Stihl Saws
TS400 has problem drawing fuel on inital start of the day 14plus pulls. fuel must be returning to tank leak back. as it starts usually first pull after inital start.
You could be flooding out the unit, and then starting it after it is flooded. This could be the reason that it is so hard to start. The maximum amount of pulls on choke should be only 3, then move it to the next setting. This should help to make it easier to start. If the unit runs ok after it is started then this is most likely the reason why it is so hard to start. Let me know if this helps. You can click on the add comment button below and let me know. I hope this helps you out.
Mar 31, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Saws Logo
136 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
