Question about Measuring Tools & Sensors
Weather station nanny cam wont read outside temp
Posted by Natalie Hjerth on
5 Related Answers
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Posted on Feb 11, 2010
Anonymous
SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
Posted on Oct 19, 2010
Anonymous
SOURCE: I have a Sharp SPC502
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Posted on Jan 02, 2011
Ray Nardo
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
c20cdn
  • 167 Answers
SOURCE: Ultronic clock. weather station, where does it get the temp
There must be an outside sensor somewhere, usually a small white plastic box, some have a display, some don't.
Posted on Mar 10, 2015
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
ACCU-TEMP WEATHER STATION, MODEL IW007A. IS THERE A MANUAL FOR THIS DEVICE?
Let's find out. Google (ACCU-TEMP)(IW007A)(manual) without parens.
Oct 27, 2016 | Measuring Tools & Sensors
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
I've put the batteries into both stations and still am only getting my room temp nothing else.Do I need to install the one outside before I'll get a reading of the outside temp?
first you must make sure the station inside and the station outside are on the same Channel. then look for the reset button on both the one outside is probably in the battery house as well as the station selector switch. after resetting both they should be able to talk to each other again.
Oct 08, 2014 | Measuring Tools & Sensors
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Have a Nexxtech weather station. How to I change temp reading from fare height to celsius?
Has anyone fixed this? I have the same problem. The outside unit is in C but the indoors one in F and I can't work out how to change it
Oct 24, 2013 | ATOMIC Measuring Tools & Sensors
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Measuring Tools & Sensors Logo
135 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
