Question about Al Agnew Watches
What size battery does my Al Agnew majestic morning pocket watch need and how many does it need to work?
Posted by Dennis Cox on
2 Related Answers
Anonymous
  • 65 Answers
SOURCE: 2003 deer pocket watch Al Agnew is it wind up or
Often with battery powered watches the word "Quartz" will be written on the dial. In the abscent of that you can look at the mechanism inside (typically by removing the case back).
Alternately (this may not be an absolute confirmation) with the winder in neutral position i.e. pressed all the way in, turn the crown (winding button) and if it spins freely it's probably quartz. Because unless it's broken most mechanical watches click as the watch is
wound up (except some automatics which cant be crown wound).
Plus if it's working and left unworn for a few days yet continues to run it's probably quartz.
Please rate this solution.
Posted on Jul 27, 2009
David Tolond
  • 2501 Answers
SOURCE: How to do you open the case to change the battery?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Posted on Mar 03, 2010
HOW TO REMOVE STEM FROM AL AGNEW POCKET WATCH
if you know the movement you can search on how to do this, There normally is a lever or a push pin hold that needs to be pressed down to remove the stem.
Sep 21, 2018 | Al Agnew Watches
What size battery is in a phillip crow pocket watch
Pop the back off the watch with a pocket knife and look, they use so many types of small button batteries it is hard to say, better to look at it and record the battery number.
Nov 23, 2016 | Pocket Watch Watches
What size of battery do i need
It is most likely a 364
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 23, 2014 | Colibri Pocket Stainless Blue Dial...
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
Pocket watch is wound but still doesnt work
I would suggest that you change the battery. The battery might be weak, and that could be the reason its not working.
Take care.
May 21, 2010 | Watches
I need help identifying waltham pocket watch
Try going to "http://www.antique-pocket-watch.com/".
This site seems to be a good point in the search for information on antique watches.
It has a few links to other sites.
Mar 13, 2010 | Chase IK7A Waltham Antique Watch
Mar 02, 2010 | Al Agnew Al Ag 3 Piece Pocket Watch...
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Feb 10, 2010 | Chase C6A Waltham Antique Ps Bartlett...
2003 deer pocket watch Al Agnew is it wind up or Battery
Jul 26, 2009 | Al Agnew Al Ag 3 Piece Pocket Watch...
Watches Logo
161 people viewed this question
Top Al Agnew Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you an Al Agnew Watch Expert? Answer questions, earn points and help others
