Question about Radio Communications
Require user manual to set up frequencies for channels
Posted by Amanda Powell on
2 Related Answers
  • 102366 Answers
SOURCE: require manual and frequency
What make and model scanner?
Posted on Apr 23, 2013
  • 102366 Answers
SOURCE: require manual /frequency
Transceiver is locked on Channel 1. Up/down buttons and channel knob have no effect.
Hi Bob,
Firstly, you say you purchased the unit NIB = New In Box, so that would mean you should also have a user manual that came with it.
If this is not the case, take the whole box and dice, together with the purchase receipt to the place of purchase and ask for a copy of the user manual, which won't cost a thing.
If, on the other hand you do have the manual, read the instructions carefully, before you turn the radio on.
It will guide you step by step on how to get your radio setup & running.
And if frequencies are required to be programmed into it, it will tell you exactly what is required to do so.
If during the course of setting up your radio for reception, you encounter problems, then towards the back of the manual there will be a trouble shooting section.
All being well, you should be up and running, if you follow my advice.
I hope I have assisted you.
Best regards,
Peter
Nov 19, 2012 | Vertex Standard VX-1700 FCCver. HF...
Have a new uniden bc355c scanner. How do i program frequencies into the private channel so that those are the only frequencies scanned.
With all due respect, I suggest reading the user manual that came with your scanner. The user manual is the best reference material there is. for this product. If you need frequencies go to www.radioreference.com
Jul 09, 2011 | Uniden BC350C Base Scanner
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
What is the frequency range for motorola t5420?
All factory installed frequencies are between 462.000 - 468.000 MHz. They consist of FRS frequencies and some GMRS frequencies.
Here is a link to the User Guide (which does not seem to have a frequency chart) http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
Best regards.
Apr 05, 2010 | Motorola Talkabout T5420 (14 Channels)...
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Akai CT21W30AT Manual Tuning
It sets the channel according to the frequency they are on, If you don't have any channels below those numbers and are connected to Cable TV, you have a bad tuner
Mar 13, 2009 | Akai CFT2490 24" TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Radio Communications Logo
126 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
