Question about Casio PX-830 BK Privia
Privia PX-830 playing everything an octave too high. How do I re-set? Thank you.
Posted by Dawn Constable on
1 Related Answer
4L60B4R1UM
  • 133 Answers
SOURCE: Turned on the Privia PX-575R and sound distorted,
You should probably check the bender controller and the master volume potentiometer, they might be dirty / oxydized, in such case, you need to either disassemble and clean them or replace them.
Also check for bad solder contacts on wires, connector pins and any of the components (e.g. voltage regulators, capacitors and/or other components).
Check all connectors for any dirt / oxydation on the pins and clean them if necessary.
Also check the main power switch (dirty contacts may result in erratic behaviour of the unit), and, if we're talking onboard speakers, see if the speaker protection mesh is somewhat loose, it may vibrate and cause the speakers to have dirty / distorted sound (you need to fix the mesh firmly in place to stop it from vibrating).
It could alse be a problem elsewhere in the unit (a bad resistor or capacitor, possibly some other component), these are just some of the things that may cause the unit to have dirty sound.
Hope you can make it sound well again.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
How can i do the reset factory for a piano Casio Privia PX-120?? It have the tone/settings button but not the function button. anyone know?
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 12, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
I connect the piano to midi and them the speakers stopped sounding, the phones plug too. how can i do the reset factory for the privia px 120?? thanks!
Lets start :::
Mar 11, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
Privia 830 factory reset
TRY this;-
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Jan 11, 2014 | Casio PX-830 BK Privia
Today I received my new Privia px830 and three keys works as an interruptor: play notes at full intensity. Are sensors cracked?
The sensors are rubber, and don't usually crack. Most of the time they are dirty and can be cleaned with rubbing alcohol and Q-tips VERY carefully. Also be careful of the ribbon wires inside the keyboard. The keys should just snap in and out. I cleaned mine a little while ago, and now it works perfectly.
Jan 06, 2013 | Casio PX-830 BK Privia
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
I have a Casio Privia Px330. On a split keyboard how do I alter the right hand tone?
On page E11 of your manual... see the picture with two voices, one for the T and one for R... select them there.
Your manual can be downloaded here: http://support.casio.com/pdf/008/PX330E1A_web.pdf
You probably cannot "change the tone" of the two voices if they are the same voice. You should be able to transpose to different octave however.
Feb 03, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Hi, the sustain pedal on my Casio PX-830 has a constant squeak now after 6 months, any ideas on a fix for this? Thanks.
clean with q-tips and rubbing alcohol around the moving parts, let dry 5 min, and some graphite lubricant may help. graphite is a slippery dry powder good for reducing friction on moving parts. comes in a little tube, normally sold buy the key making dept at any store
Dec 21, 2010 | Casio PX-830 BK Privia
Casio PX-830 BK Privia Logo
137 people viewed this question
Top Casio Music Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Tim Brauer
Tim Brauer
Are you a Casio Music Expert? Answer questions, earn points and help others
