Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Dlink dap 1522
I have a linksys wrt54g router and want to connect the dap-1522 to it. im using vista and i remember that i read somewhere to go to start and conntect to and should be able to connect to the accesspoint/bridge, and one time i used it and it worked but now it doesnt seem to be seeing the ap. it didnt work ive tried dlinkap and 192.168.0.50 and still cant connect to the ap/bridge. is it not possible to connect the linksys wireless router to the ap/bridge?
first i was having problems with the linksys router so i purchased a new dlink router n capable dlink dir-655 i believe. it worked great, but because the size of our property even this powerful router wouldnt extend to the area we'd like.
After taking a suggestion from a family friend we were told to purchase a wireless access point or bridge to basically "bounce" the signal again. Ive heard of it being called a repeater but not sure. anyways, we decided to buy the dlink dap-1522 and attemp to connect to the linksys router. why cant i manually connect to the dap-1522 through ethernet ports? am i doing this all wrong? misunderstood? any suggestions would be appreciated. Thanks in advance.
Anonymous
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Posted on Aug 31, 2009
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
Feb 16, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1522 setup wizard
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. Example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
Jun 05, 2012 | Computers & Internet
DAP-1522 WIZARD
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
Apr 04, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Im trying to install a DAP-1522 as a bridge with my Linksys WRT610N V2. How do you do it. I find DLINK very hard to set up
Hi Friend,
Please follow the steps to install the DAP-1522
1) First connect your computer to the linksys router with a wire,dont connect the DAP. Now if u have windows XP please try this
2) Now ,click the start menu>run>type cmd and hit enter
3) In the black window,where the cursor is blinking type ipconfig/all and hit enter
4) Out of the bunch of information please note down the ip address and the default gateway
5) if the default gateway is 192.168.1.1
6) disconnect the computer from the computer and connect the DAP to the computer directly
7) click start menu>control panel>to your left you will see "switch to classic view",please click that>double click the icon named network connections
8) Inside network connection you will see an icon named Local Area Network connection,right click and click properties
9) under the general tab you will see Internet protocol(TCP/IP),select that and click properties
10) In the new message bos you will see 4 radio buttons,select the second one from the top
11) in the Ip address box type 192.168.0.1
12) Click ok and then close
13) now open the internet explorer page and delete evrything from the address bar and type the number 192.168.0.50
14) You will get the page of your DAP
15) set the fixed ip of the 1522 to 192.168.1.50,DHCP should be disabled.
16) Make sure that you have set the wireless password so that no other people can mess up with your network
170Save the settings.Once done unplug the bridge and enjoy working wireless.
Warm regards
Chiranjeet Mitra
3)
Oct 08, 2009 | Computers & Internet
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
1,923 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
