Sharp AR-168S Copier Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After insalling new toner I got system error F2-04
Chris Coughlin
Level 2:
  • Sharp Expert 1,326 Answers
  • Posted on Aug 17, 2009
Chris Coughlin
Sharp Expert
Level 2:
Answers
1326
Questions
Helped
441721
Points
872
Are you sure you removed all the packing tape and paper from the cartridge before installing it? Are you sure it is the correct one?
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
1helpful
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
I ran my HP Laserjet 1022 out of toner and when I insalled a new cartridge It never loaded the toner and does not print.
slap it from back side of printer your problem will be resolved if it persists then check the cairtage holder for broken if it is so then replace the older your problem will be resolved .
I have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help.
i have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help
1helpful
When insalling flashdrive error code tn-19166
It's a driver issue, find the manufacturer's website for any known fixes to your flashdrive.
System error [f02-04]
I believe you asked the same question before.... Make sure the waste toner cover / plug is removed and that you shook the cartridge to loosing the toner. You may have recieved a bad or defective toner cartridge...Good Luck
11helpful
2answers
Trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
2answers
System error
hi,
the c7100 error is a problem with the Auto Toner Sensor.
the first this to check is that you are using a genuine toner cartridge.
if you are please try to re-set the developer by keying in 1087 1087
then 130 press start and then start again once this is done please press stop twice, then 001 and start
if this does not fix it it may need either a new sensor or a new developer unit.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
