Scott Alt Posted on Jun 25, 2019
My boss rebel bluetooth speaker has a flashing blue light while on. Can I turn that light off while music is playing somehow?
5 Related Answers
A
Anonymous
  • Posted on Jun 03, 2008
SOURCE: Music will not shut off on phone
The feature for Background music is Feature 19. You can put that feature on a button, then turn it off and remove the button.
Anonymous
  • 5 Answers
  • Posted on Jun 11, 2009
SOURCE: Play music from Iphone through car speaker system
If you car has a tape player then you can get one of those tape adapters and plug it into the headphones part on your iphone, then it will play through your speakers.. or, if you want to spend some money, you can take your car in and have them install the ipod hook-up.
Anonymous
  • 73 Answers
  • Posted on Aug 26, 2009
SOURCE: How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Anonymous
  • 159 Answers
  • Posted on Jan 14, 2011
SOURCE: The zeppelin no longer plays
the flashing blue light normally indicates the ipod is on pause. if the unit is not on pause, the problem could be the arm or the interface board, they power suppy could also be the old type, so suggest you contact b and w service if you have not already. (if there is an issue, ask them if your serial number has the updated or the problematic power supply unit!)
logosc75
Larry Spears
  • 625 Answers
  • Posted on Sep 29, 2012
SOURCE: My JVC KD-G340 says its bluetooth capable but when
Your Stereo requires a bluetooth adaptor (KS-BTA-200) for the bluetooth to function. Here is a link to the owners manual for your particular device:
http://resources.jvc.com/Resources/00/01/13/GET0487-001A.pdf
The information you require is on page 10... Bluetooth device operation.
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
How do i play music from my phone on my philips micro music system btm2180
1. On the Philips music system, press FM repeatedly until [BT] (Bluetooth) is displayed on the display panel. The Bluetooth indicator flashes blue.
2. On your phone, go to Settings and turn on Bluetooth. Press Scan. Your phone will start searching for nearby Bluetooth-enabled devices.
3. Select 'PHILIPS_BTM2180' on your phone and, if necessary,
enter '0000' (no quotes, all zeros) as the pairing password/key.
After successful pairing and connection with the phone, the Bluetooth indicator on the Philips system will turn solid blue and you will hear two beeps coming from it.
4. Start playing music on your phone and enjoy hearing it from the speakers on your music system !.
1helpful
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
How do i pair my phone to play on my insignia speaker?
1. Press and hold the button to put the speaker in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the speaker.
2. Turn on Bluetooth on the phone and tap on Scan. The phone will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the speaker's name, tap on the name to pair with the phone. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the speaker will turn to a steady blue and you will see 'Connect' on the phone. Tap on Connect and then you will see Connected on the phone. Your phone and the speaker are now connected.
The steps above should be detailed in the set up guide that came with the speaker. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the phone to the speaker, a "get to know you" procedure. After that, you just need to connect the two.
2answers
How to connect a BT20 Polaroid speaker to bluetooth
Press the play/pause button whilst you turn the power on, then connect.
2answers
How do i sync my phone to my smps-650 wireless speaker
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
2answers
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Unable to connect Sony Xperia Z1 to Altec Lansing T515 bluetooth portable speaker
1 does it have bluetooth
2 is it turned on
3 have u searched for devices i.e. in settings -- music -- play over bluetooth -- select device i.e. Portable Sound System Device / Click / Ok / Play?
3helpful
4answers
I can't get my Polaroid Bluetooth wireless speaker to work!
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
2answers
Music won't play on my bluetooth headphones.
If your handset does not support stereo music on blue tooth headset, then you can not hear music on blue tooth head set. However you are able to answer and make calls through blue tooth headset.
Top Blue Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
