Question about Samsung Audio Players & Recorders
Brand new Samsung smart tv and Onkyo stereo receiver 8200 with optical cord connection I am getting distortion when I try to watch Netflix no distortion when I switch back to tv speaker
Posted by Helen Reid on
5 Related Answers
Anonymous
SOURCE: ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Posted on Nov 15, 2008
Anonymous
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
memturbo
mark gardner
  • 234 Answers
SOURCE: no sound from xbox to stereo using an optical out from TV to amp
If Im reading this right what you need to do
is hook the audio from the xbox to the stereo system
not to the tv .
Posted on Apr 04, 2009
Anonymous
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
Anonymous
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
2answers
I'm trying to connect my old onkyo tx-sr502 receiver to my panasonic smart tv and my xbox 360 to get surround sound. Any help would be appreciated
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
No sound from new sony uhd tv on the Onkyo sr606 receiver when watching smart content like netflix.
Hi AB, best way to accomplish this would be to go from the TV's audio output to any open audio input on the 606 and just be sure that you assign the source to the input. If you require further assistance please feel free to give us a call at 800-229-1687, also note that we offer a trade in program if you are looking to upgrade to a newer receiver, please email me your current units serial number and I will advise if it qualifies for the program. You can email me at [email protected], Thanks, JT
2answers
How do I get Netflix on my tv
First you need a Netflix account. Then, if you have a smart TV, it needs to be connected to the internet and have the Netflix app. If your TV is not smart, your DVD player probably has Netflix on it and that needs to be connected to the internet. Then you have to log into Netflix on your computer and authorize the new device. They will give you an activation code to enter on the device.
Watch netflix with samsung TV
Hi , It is easy to have bbc iplayer or UK or US netflix on Samsung smart TV and watch it outside the UK or US
there are two way to do , one is using DNS ,, but no recommended because it blocked occasionally, so the best way is use reliable VPN provider which you can get from this link http://www.overplay.net/#a_aid=vpnprovider
you can get the account and pay for one month 10 $ or one Year 100 $ VPN + smart DNS , also you can ask for refund if not work for you so you are in safe side!
after getting your account ready , you need VPN Router , and technology of VPN better should be openvpn it is faster more stable than pptp or l2tp because it reconnect if even your main connection drop and restored
once your VPN router is ready , just reset your samsung TV to factory default , you can go to TV manual and do it
connect your TV directly to the VPN Router for your reference connection should be like below
Main Internet Router -----> VPN Router ------> TV
restart your TV and live it for 30 minutes ! vola you will see netflix , Pandoora , Spotify will apear on TV apps , just enter your user name password of netflix and start enjoying it !!! let me know if this helps?
2helpful
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
2answers
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
2answers
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
