Hi Tyrone, I'm looking at the Yamaha HTR 3063 manual and it does not have the Tape-Monitor function, which would allow you to have the connections for an equalizer
This happens because of the variety of types of audio signals and they can not be processed for the insertion of an equalizer
Eventually, you could equalize a single signal, which you would connect to the EQ input and the EQ output, connect it to any of the RCA L-R audio inputs
Greetings Franco Dosil
Hola Tyrone, estoy viendo el manual del Yamaha HTR 3063 y no cuenta con la funci?n Tape-Monitor, la que te permitir?a tener las conexiones para un ecualizador
Esto sucede por la variedad de tipos de se?ales de audio y no se pueden procesar para la inserci?n de un ecualizador
Eventualmente, podr?as ecualizar una sola se?al, que la conectar?as en la entrada del EQ y la salida del EQ, la conectar?as alguna de las entradas de audio RCA L-R
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/7/321147/HTR-3063_om_en1-1.pdf
https://data2.manualslib.com/pdf3/65/6430/642969-yamaha/htr3063.pdf?6a90cbe355c2bdc4e399d09c40d1a7ab&take=binary
SOURCE: How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
SOURCE: I have a Yamaha HTR
The codes for the Yamaha with this remote are
0205, 1017, 1030, 1033, 1039, 1040, 4014, 4030, 4046, 4102, 4511, 5013, 5027, 5036, 6012, 6012, 6022, 6038
Try each one until you get the correct one for your receiver.
Please do leave a vote for the solution. Thanks.
SOURCE: I recently bought the yamaha
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
SOURCE: where can i get firmware
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
