Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
How to use bellsouth router on windstream internet
I have a bellsouth westell versalink wireless modem/router that I would like to use on windstream DSL. It asks for a username and password but the windstream one causes an error. Is there anyway to override this or will I have to buy a new router? Someone else on here was able to get a verizon one to work, will it work with the bellsouth one also? I appreciate any help! Thanks!!!
Posted by paulibj on
Anonymous
    New Friend:
  • 94 Answers
Yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now [email protected]
Posted on Aug 16, 2009
Do i need a wireless router if i have westell 6100f
Yes. The Westell 6100f is not a wireless modem, therefore, you will need to get a wireless router to connect wireless computers.
Or if your ISP is Verizon and you want a wireless modem/router, you may contact them and replace the Westell 6100f with a Westell Versalink 327w, or Westell 7500, or an Actiontec.
Hope this helps!
Mar 01, 2010 | Westell Wirespeed LiteLine 6000 Modem
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
Wireless icon shows full strength however internet does not work. Internet button blinks.
Has your wireless router/modem been configured to your ISP's instructions.
The blinking PPP or Internet LED means the wireless router is not connecting to your ISP.
You should also contact your ISP to get them to test the connection to your router/modem especially if you have a DSL modem.
Sep 20, 2009 | Westell Wirespeed VersaLink...
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
May 29, 2009 | Westell Wirespeed VersaLink...
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
My versalink modem
if you meant connecting it to a modem it is possible. but if you meant connecting it to a computer to share internet to other computers, then it won't work
Jun 04, 2008 | Westell Wirespeed VersaLink...
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
571 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
