HP DeskJet F4280 All In One Printer InkJet Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing sideways how do i change to normal - HP DeskJet F4280 All In One Printer InkJet
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
24186
Points
237
In the settings try changing your settings to portrait, from lanscape printing.
  • Solo Mama
    Solo Mama Feb 25, 2014
    This does not work for me and is the most obvious solution. The settings have been changed yet the printer continues to print in landscape although the portrait setting has been checked.
Click landscape in print dialog box but only turns portrait sideways
Landscape is Portrait sideways :>D
Normally you have to tell the program (Quickbooks) to print Landscape and then you tell the Printer in Properties to print Landscape.
I just had the same in Publisher to a Canon MFP MG1720.
From the QuickBooks File menu, select Printer Setup. Click the Form Name drop-down and choose Report. Click the Options button next to the Printer name field to open your printer properties window. Go to the Finishing tab and in the Orientation section, select Portrait or Landscape.
Save QuickBooks Desktop PDF in legal size, landscape, or ...
How can I print sideways?
Instead of hitting PRINT, there should be an option listed as PRINTER SETTINGS or better yet, PREVIEW. You should see an option for landscape or portrait and various other settings! Hope this helps! :-)
2helpful
Print result sideways
It sounds like your printer is set to print landscape, instead of portrait mode. Next time you want to print, click on file(top left of screen), then print (don't just click on the little printer icon). This will open a new printer window where you can choose different setting. The option to change from landscape to portrait will be listed somewhere in that window. Once you have selected that feature and print it will stay that way unless you change it. You will have to check this setting in each computer program you use.
2helpful
2answers
My screen is sideways and i cant get it back to normal
Right cllick on your desktop and choose personalize. At the bottom of the left panel click display and then click change display settings. Click on the orientation drop down menu and change it to landscape.
Fax Print Sideways
problem has to be on the sending side..
Printing-Supercalc 5-Spreadsheet-, Sideways
just to check if the printer and the printer driver is working properly, try printing a 2 page document.
if it prints out correctly - check the applications documentation / user guide for printing instructions.
1helpful
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Fax received printed sideways, 50% size
If its not constant its probably on there end. Does it happen with any other party. Lawrence
k24674
Grand Canyon Tech
Grand Canyon Tech
