Question about Music
How do I remove a mixer output insert to replace it
Posted by Justifiedbandva on
  • Scott Fellows
    Scott Fellows Oct 01, 2019
    Most input/output components soldered to circuit board in 3 places. Not difficult to do if you can get access and have proper tools. Just dont heat board too long or you can damage traces.
Steve Cox
    Master:
  • 674 Answers
Assuming you are talking about a jack and you are asking this question, pay a tech for this.
Posted on Sep 30, 2019
I use 5 out of 6 aux. for monitor...That leaves only 1 aux. for delay/reverb. is there another way to hook up delay/reverb to mixer?...SR24-4 mackie mixer...
It sounds like you're new to 'professional' mixers. You would NEVER normally use an aux for effects. Any effects will normally be inserted in the sound chain using an insert. You have a pair of group inserts if you are wanting to apply an effect to the output (these are after the mix) and would typically be used for master de-essers or possibly compressor limiters or maybe even an equaliser, it would not be sensible to use an effect like a delay/reverb here.
I would have expected you to be using the group outs for the monitor mixes and am not sure what you may be using them for otherwise. If you used these you would free up 4 of the Aux outs for a 'multi channel' reverb/echos which you could take back into other channels and back into the main mix.
What is it you are tyring to achieve?
Apr 03, 2014 | Mackie 2404-VLZ3 Mixer
No output on the master but there are output on group and aus out
broken faders...bad muting fet on master buss, dirty insert jack on stereo buss...could be a lot of things, last drive stage to output, got hot neutral feedback on snake and blew the final stages...
Nov 13, 2013 | Peavey 16FX 16 Channel Mixer
Behringer PMP5000 Mixer. Connected a speakerOn cable to Output A while device was ON. Went to do the same thing on Output B and heard a spark. Turned off the mixer. Now, it will not come on. Checked the...
Chances are you've blown the output transistors. Speakon connectors cannot short out but jack connectors can and if it was not inserted properly you'll have presented a dead short to your powered mixer. In any event it is really bad idea to connect anything when it's switched on. If you're really lucky replacing the output stage (which will probably be dead short on the transistors) and re-adjusting the bias should sort you out.
Apr 08, 2017 | Behringer Europower Pmp5000 Powered Mixer...
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
I can't get any sound to go through Mackie 1604-VLZ3. I've tested to insert sound to every channels and checked all button positions and nothing comes out from main output or the phones....
There is NO way to select channels to "Source"... The selections on this mixer are to send the channels to SOLO, Sub1-2 or Sub 3-4 and/or main L-R. You should have the bottom button for each channel punched down to L-R. NEVER connect ANYTHING other than an external effects unit to the INSERT jacks!!!! These jacks are combined output/input jacks with send and return on the same jack. Special insert cables are used for these. An external drum machine should be connected to a line input for one of the channels USING a TRS balanced cable. Page 28 of your user manual shows the block diagram and signal flow diagram. The trim control is the input gain control. Start with those say at 12 o'clock and advance the fader for the channel of interest...you should get signal at the main outs. MAKE SURE that the lines from the mixer to the amps are BALANCED TRS type cables... You cannot use unbalanced cables for this. The user manual explains balanced cables and what they look like. I just repaired one of these mixers that some foolish people plugged stuff into the MAIN INSERT jacks and blew out the driver that drives the MAIN insert which kills the input to the MAIN output drivers. There is one small chip between the AMAIN fader and the sub next to it and one has to remove every knob and take the unit all apart to get to it... It is a tiny surface mounted part the size of a matchhead with 8 leads... not for the faint of heart to repair. As a test of this part, you can plug a st of headphones into the RIGHT MAIN insert jack and drive audio into a channel... turn trim control up fully for the channel and the fader on full, and set the PAN control to 12 oclock and punch down the L-R button for that channel. You should hear the audio in ONLY the left ear... Now try the phones in the LEFT INSERT jack... you again should hear the audio in the left headphone only (these jacks are not stereo like the headphones). If you cannot hear anything, then likely somebody has blown that driver in your unit... It is painful and time consuming to repair this... there are hundreds of knobs to pull off and put back on... dozens of screws and cables and to get it all back together. Also make sure ALL of your interconnected equipment is powered from a SINGLE receptacle or power module. Read your user manual thoughroughly. You can get one online download if you need it.
Sep 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have a mackie cfx12 mixer. I just added an eq with sub woffer crossover via the main inserts using the proper insert cables. System works great, however when Using a CD player the subs will not work. any...
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Jul 22, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Channel mixer problem- No channel B output.
Probably time for an upgrade to a newer channel mixer. Your mixer is probably not worth fixing, but you could continue to use the mixer side for a while until you decide to upgrade that. If you happen to know an electronics tech, it could be a little project to check the power amp insert jack on channel B, but it wouldn't be worth spending good money after bad when you could put it towards more solid gear.
Good luck.
The dude.
Aug 07, 2008 | Peavey 32fx USB 32 Channel Mixer
Music Logo
143 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
