Question about Briggs Measuring Tools & Sensors
Ariens zoom 42 mower keeps flooding with gas, why or what is the possible cause to this? We have removed the carbuetor and cleaned it out (even though it was not dirty) and replaced the spark plug.
Arienz Zoom 42 and has a briggs and Stratton intek ohv engine. Just runs for a minute and kills....it is getting too much fuel.
4 Related Answers
Anonymous
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
Anonymous
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
Repair Ahjoshe
  • 885 Answers
SOURCE: what would make gas flow out of the spark plug hole on a briggs and stratton 18hp ohv intek?
If you are getting that much gas out of the cylinder you most likely have a stuck fuel float valve or the float itself is damaged in the carburator. Make sure you check your crankcase for gas also, usually when a float valve sticks it also fills up the crankcase with gas. Hopefully you just have some debris caught between the needle valve and seat that can be blown out. If not replacing the needle valve and seat or float is relatively inexpensive.
Posted on Mar 02, 2012
mike butler
  • 6468 Answers
SOURCE: Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
Posted on May 10, 2012
Zoom 42 mower deck belt routing diagram
Andy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Zoom 42 mower deck belt routing diagram Google Search
http://apache.ariens.com/manuals/00173200.pdf
How to Replace the PTO belt on an Ariens Zoom Zero Turn
Ariens Zoom 42 Owners Manual
May 07, 2016 | Garden
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
Remove gas from Ariens 42" zero turn lawnmower
easiest way is to remove the tank and dump it out. you can also remove the fuel line at the carburetor and allow it to drain out there into an approved container. if you choose the latter be sure to have the cap off the tank to allow air in
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 29, 2013 | Ariens Garden
Ariens sport zoom 1232.It stopped running,will not start unless
Small piece of dirt or debis under the fuel inlet needle causing the engine to flood out. I would clean the seat with a q-tip and a little jewlers rouge, polish the seat and install a new needle. Hope this helps. If it still leaks then replace the needle and seat due to it being damaged
Nov 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Electric start turns over, but engine doesn't start. Ariens snow thrower. Series 932
If gas has been sitting in the carburetor since last season, The carburetor will need to be cleaned out and rebuilt. Some ports may be clogged up that allow gas to flow.
HTH
Good Day.
Oct 30, 2009 | Ariens 34 In. Zoom Series Riding Mower
Measuring Tools & Sensors Logo
123 people viewed this question
Top Briggs Measuring Tools & Sensors Experts
Vernon Taylor
john h
Andrew Taylor
Andrew Taylor
Are you a Briggs Measuring Tool and Sensor Expert? Answer questions, earn points and help others
