My built in webcam cannot be detected eventhough the driver is already installed. Every time I open the cam its says ''cam not connected''.
This laptop has that problem from design and need the original operatie system from manufacturer for fix it !
Make sure the program that your using doesn't have the camera offline.
Then if the driver installed properly and you see the camera listed in the device manager then the next step would be to open up the LCD. You'll need to turn off the laptop.
Take the rubbers off of the lcd bezel then unscrew the screws out of there. Take off the lcd front bezel and this will expose the screen and also expose the built in webcam. Make sure the connector for the webcam is actually plugged in. You might have to reseat the connector or best thing is disconnect it and then reconnect it back.
Now go ahead and turn it on and use the webcam program and see if it works, if it still doesn't work then the built in webcam is bad.
