Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint wd72 - Keeps "close door" message up, wont turn off. Did trip switch and went bang when turned on! black mark by door handle!
    Brigadier General:
  • 4,090 Answers
Short circuit on the door switch module
Posted on Aug 16, 2009
Testimonial: "Thanks, found that our builders knocked it on a door frame when moving it so must have caused damage resulting in short circuit"
    New Friend:
We have a Hotpoint wd72 after selecting pro gramme it says starting followed by message of close door and it gives a low 'beep'
The door is closed but the machine still thinks it is open.
HELP...
Jo
Posted on Oct 29, 2009
6ya staff
SOURCE:
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
HOTPOINT WASHING MACHINE wmf540
You will have to find the component in the machine that has
gone live to neutral,live to eath or neutral to earth if it is protected by a RCCBO. Check on the back of the printed circuit board for "BLOWS" black marks blown components.
Jan 10, 2014 | Indesit Genuine Hotpoint Wmf540 Wml520...
Went bang tripped fuse now wont turn on
Did you flip the switch in the switch box back on?
Dec 26, 2013 | Kitchen Ranges
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
this is a regular fault with these machines im looking at three of them its definatly the PCB nomally you will see a burt out track or something on the corner of the baord im afraid you will need to replace this part if you decide to do this mark all the plugs on the pcb with coulored felt tip pens to avoid putting them on the new board in the wrong place definatly worth repairing exellent machine
Sep 03, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima washer dryer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
330 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
