I need a schematic fro a Pepsi SOHO radio. Where can I find one, ?
This is a small radio shape like a juke box
Posted by Chris Kaplon on
1 Related Answer
Anonymous
SOURCE: LCG Juke box version 2.30
help me for unlock key LCG jukebox 2.30 IMEI 353641013484781
Posted on Oct 11, 2008
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Estimated valur of my 1937 mills studio juke box swing king
of course condition plays a roll in all things of value but if its in decent shape probably somewhere 1200 to 2000 range..
If you need further help, reach me via phone at https://www.6ya.com/expert/allen_b068623c5003aa4b
Nov 06, 2014 | Cell Phones
How to a install a N44-7 shure needle on a juke box tone arm
The metal end of the stylus is diamond shaped. The slot you are trying to put it in is a slightly larger diamond shape. Put the top edge in first and gently insert. If there is a problem it is maybe because the fingers in the cartridge are bent.
Sep 09, 2014 | Wurlitzer Jukebox CD Player
Crosley cr12-10 schematic
just purchased new 3 days ago. removed music cd from car to play in jukebox. would not play any disc 1-10. would keep on changing to next disc without playing.......help!
Nov 25, 2011 | Crosley Juke Box CR12-10 Shelf System
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Need a schematic diagram on a uniden grant lt
http://www.cbtricks.com/radios/uniden/grant/graphics/grant_sch.pdf
Jan 29, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
