Question about Mercury Boating
My 1991 75hp outboard has a constant beep alarm. what is it and what can i do ? Mercury brand
Posted by Larry Ross on
4 Related Answers
Anonymous
SOURCE: 4 beep alarm - Mercury 150 efi outboard
hi,
when the engine is running there is a repeated 4 beep alarm every 5 to 10 min. i have talked to several repair shops and they are unsure of the problem. what is the proper solution to fixing this alarm?
Posted on Apr 29, 2010
philwalker78
Phil Walker
  • 608 Answers
SOURCE: I have a Mercury 90
Hi, follow the wires from the bottom of the oil reservoir and unplug them at the connection. If the alarm stops then the sensor or built in float is faulty. Replace the sensor first, if this solves the problem no more action is required. If it still alarms you will need to replace the reservoir as well, as the float is not removable. Hope this helps, regards Phil.
Posted on Jul 07, 2011
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Posted on Apr 13, 2012
bonacci1528179
johnny bonacci
  • 258 Answers
SOURCE: What might cause the warning system on mercury 50hp outboard to beep 3 times every 4 minute s
That is the engine default code. It has to do with the regulator not getting enough water to cool it down. Those are water cooled regulators not air cooled like cars. The impellers for the cooling system should be replaced about every 3-4 years. It may still cool the motor but not enough to cool the regulator which supplies the computer to set the trouble codes.
Posted on Jul 21, 2018
Testimonial: "Is it safe to use the pontoon and wait til fall to replace the impeller"
75 hp mercury outboard motor constant beep alarm
Your engine is not running cool enough. OR SOMETHING IS WRONG with oil injection.
Jun 25, 2018 | Mercury Boating
2006 mercury outboard opti max 200 engine alarm, (4 beeps). oil was run low, do i need to prime the system or should it prime itself?
The low oil sensor is not "seeing" the oil in the tank...(mine does this when I crank it,, the low oil light stays on).. It uses plenty of oil,,I quit worrying..- -don't feel like taking the oil system apart..
Get one of these.. I have one for every outboard I ever owned..they DO come in handy...
Mercury Outboard Manuals by Seloc 1965 2014
Jul 31, 2017 | Mercury Cars & Trucks
Why is a constant alarm sounding when ignition key is turned on?
Just had the same issue with my 92 mercury 2 stroke outboard. It could be the oil sensor temp sensor or the moduel for the 2.
Jun 15, 2016 | Boating
Mercury outboard problems
The alarm is the overheat horn. It means that your motor isn't pumping water from the bottom of the leg and through the engine cooling ports. You will see water shooting out the side of the motor when it starts getting hot, and if you're not seeing the water shoot out and the horn is on then chances are the pump impeller on the leg is shot. You should never start a boat motor (outboard or any other type of boat motor) without having it sitting in the water or with a water calliper with a garden hose attached on the lower inlets of the leg. If you run it without water you will melt the rubber impeller and damage the engine if it's run too long without water cooling. Take it in to a qualified tech to replace the impeller.
May 25, 2014 | Boating
Hot engine alarm on my 1998 115 hp mercury outboard as soon as you turn the key on the alarm comes on and does not stop until you turn the key off ?
Alarm is also for low oil but cold be faulty relay unit for alarm.connect heat sender wire straight to alarm and just make sure you always have oil in autolube
Sep 20, 2013 | Light Outboard Motor Boat Bass Fishing...
hi,
Feb 10, 2010 | Boatmates products are the final word...
Boating Logo
197 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
