Lenovo Thinkpad R61i Notebook PC Logo
Posted on Aug 16, 2009
My trackball stopped working so I've been using a USB mouse. The mouse highlights everything on a page, clicks links and windows open without my doing anything and basically seems to be possessed! It will do this both online and when working in Word. As I move the cursur over the page it highlights everything and random windows open!
Anonymous
Level 1:
  • Contributor 51 Answers
  • Posted on Aug 22, 2009
Anonymous
Contributor
Level 1:
Answers
51
Questions
0
Helped
18779
Points
91
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
1helpful
Can't click on right
Hi!
That depends on the quality of the mouse that your using.
Cleaning/ opening the mouse will not work at all.
The quality of the mouse.
How do I print a highlighted part of a page in a .pdf file in Adobe Acrobat 9.0, with an  iMac and a Canon MP620 printer. The print window does not appear to give me the option of printing only the...
LEFT CLICK JUST BEFORE THE WORK THAT YOU WANT TO START AT AND HOLD DOWN DRAG THE MOUSE DOWN AND THE COLLORED AREA WILL MOVE DOWNTHE PAGE JUST STOP IT WHERE YOU WANT TO END. THEN RIGHT CLICK WITH THE CURSER IN THE COLORED AREA , A BOX WILL COME UP LEFT CLICK ON COPY IF IT DONT COPY JUST OPEN A NEW PAGE AND RIGHT CLICK THE MOUSE THE SAME BOX WILL APPEAR CLICK ON PASTE, WHAT YOU HIGHLIGHTED WILL BE THERE THEN COPY IT AS YOU WILL
Frozen computer and mouse problems
I am assuming you use Windows XP.
Try deleting the mouse's drivers in your computer and let it re-detect them.
Right-Clickie MyComputer and drop down to the last option of Properties.
The 2nd Tab should be HardWare. On that page, click Device Manager. Scroll down the list to find the Mouse Driver, or MICE.
Expand the list. Highlight the Mouse and right-clickie it. Select UNINSTALL.
Reboot your computer.
When it all comes back up - if you mouse is still being dorky - then it is either your USB driver [same as above, only delete the USB Root Hubs (all of them) and let that re-detect upon reboot] -
OR
You mouse is dead. Try a friend's mouse.
If the friend's mouse works - Buy a new one. They are $10 at WalMart.
You can do this in any order ... Try a friend's mouse, delete USB hubs & reboot, delete mouse drivers & reboot.
One of the three is your problem. :)
(There is a very small chance that your USB hub has actually suffered a HARDWARE failure.)
Kensington 64215 PS2/ Serial Trackball on USB Mac?
Is the trackball supported by the MAC operating system? If available try the same setup, using the adapter, on a windows based computer to troubleshoot whether it is the trackball or the Mac.
11helpful
7answers
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
2helpful
Cursor sliding off screen
I?ve had this problem in several Logitech mice. In every one of my cases the problem was resolved by uninstalling the driver and reinstalling the latest OR just using the default Windows driver. In some cases with USB mice I had to shut down the PC, remove the original mouse and replace with a standard PS2 mouse, remove and reinstall the driver and then reattach the USB mouse without rebooting. After a successful test you can shutdown the PC and remove the PS2 mouse. Let us know if that works and if you have any other questions and thanks in advance for rating this post.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
