Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
