Before you suspect the dishwasher, check the circuit that supplies power to it.
Determine if the DW's power is provided by a cord that plugs into a wall outlet or not. If the power is supplied through a wall outlet, unplug the dishwasher and plug in something like a light or a vacuum cleaner and turn on. It it comes on, then the problem is inside the dish washer.
If the power is provided through a direct connection from the circuit breaker, go to the circuit breaker box and track down which kitchen circuit ~may~ have tripped.
If the problem is inside the DW, solving that problem is not trivial and requires some special knowledge. If you investigate on your own, be 100% certain that the power has been removed from the DW for your safety.
Good Luck
