Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I just dropped my Canon SD750 and now it won't turn on. Is there a reset button?....or am I out of luck?
Posted by patrich53 on
Anonymous
  • 28 Answers
I had a Cannon EasyShare CX7000 many years ago, had the same problem exactly, Canon cameras are not that durable when it comes to dropping it, but I have a Cannon Powershot SD1000 and I have dropped it numerous times and it still functions like it's new. three words REPLACE YOUR CAMERA. oh, and there is no reset button, you are out of luck
Posted on Aug 16, 2009
1 Related Answer
Anonymous
  • 906 Answers
SOURCE: I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Posted on Jul 27, 2010
2helpful
2answers
Canon
9helpful
My canon sd750 wont rerset to defaults
Turn the camera on and do the following:
Press Menu
Press to the right once
Press up once
Press Function Set
Press Right
Press Function Set
That is the key sequence on that model to do a soft reset. If you still have problems, try emailing: www.camerasandparts.com as they specialize in the service for these Powershots. They're fantastic if you should further help, they're the place for the powershots. Good luck with it.
Have a canon digital elph sd750. Pictures are now blurry.
You could have cracked the lens, damage the focus or a number of other things but the lens and focus are most likely. check your lens for scratches if there is none and no cracks take it to your nearest camera store or buy new good luck!
1helpful
My sd750 will not start up
Does the lens cover move when you do this? If it doesn't, it sounds like that might be the problem.
1helpful
No power on Canon SD750
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
2helpful
How to change the language setting on my Canon SD750?
1. Turn the camera on, make sure it is in playback mode.
2. Press and hold the Func/Set button, and while still holding
3. Press the Menu button. Release both buttons.
4. Use the arrow keys to highlight desired language
5. Press the Func/Set button
1helpful
2answers
Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
2answers
Canon powershot sd750 dropped in a bowl of **** juice
hi,
since you have dropped the camera there must be some slight internal problem which is not letting u do some small functions.So u can take to a camera doctor.He can probably fix it and it wouldn't cost much.
Canon sd750
send it to us for a free diagnosis this power issue is very common. we can fix for for normally 85.00 worst case 125.00 depending on the issue 85.00 replaces the fuse or mainboard.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
