Question about JVC Car Audio & Video
Stereo wire color > front doors speakers
I was looking for the stereo wiring diagram for a 91 Mercedes Benz 190e (just so i know for sure i have all my stereo wires hooked up right speaker) but specifically, I'm having trouble figuring out what wire color is connected to the front door speakers
Mike Butler
  • 6,674 Answers
Try this link.
http://www.the12volt.com/installbay/stereodetail/1412.html
Posted on Aug 16, 2009
Testimonial: "exactly what i needed. THANKS "
I would like a wiring diagram for a Merc 190E right-hand front door window
Hi,if its that you have taken it apart and forgot how to put it back together,if so,take the opposit door card off and copy it.
have a good day.
Jan 04, 2015 | Mercedes-Benz 190-Class Cars & Trucks
Serpentine belt routing on 93 mercedes 190e 2.6
Go to the following link and the first photo shows the belt routing. I hope this helps as I know changing the belts on these vehicles can be a major pain in the neck.
Pelican Mercedes Benz Tech Article Mercedes Benz Drive Belt Replacement...
Dec 11, 2014 | 1993 Mercedes-Benz 190
Radio wiring code for 1987 mercedes benz 300. With aftermarket radio the windows switch ligths blinks and have no instrument ligths.
Hi, the aftermarket stereo does not use the illumination wire. You must tape that wire off (purple/gray). That wire is either connected to the wrong place or is touching chassis ground and causing your instrument lights to dim.
Connect the stereo's red wire to the car's black/yellow wire; and connect the stereo's yellow wire to the car's red/white wire.
1987 Mercedes 300E Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Purple/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre Dash
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Black
Sep 13, 2011 | 1987 Mercedes-Benz 300-Class
2 problems. 1st is that when the air is on, the middle vents work perfectly but the side vents push hot air for some reason. whats the problem? 2nd is the stereo stopped working so what would be a good...
The vacuum pods are going out most likely, spendy fix. Go to crutchfield.com for radio solutions as they have MB wiring kits to bypass the fader for new stereos.
Jan 08, 2010 | 1989 Mercedes-Benz 190
Need wiring manual for a 1992 mercedez benz E190 stereo
1984-93 Mercedes 190 Series Stereo Wiring Constant 12V+ Red Switched 12V+ Black/Yellow Ground Brown Illumination Gray/Blue Dimmer n/a Antenna Trigger Blue Antenna Left Rear Front Speakers 4" Dash Left Front (+) White Left Front (-) Black Right Front (+) White Right Front (-) Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) White Left Rear (-) Black Right Rear (+) White Right Rear (-) Black
Jan 05, 2010 | 1992 Mercedes-Benz E-Class
What is the proper wiring diagram for the car stereo system in a 1999 Mercedes Benz Clk 320
i put a new stereo in was working fine ater about 20 min speakers stoped working but the sub-woofer is still working
Jan 03, 2010 | 1999 Mercedes-Benz CLK
1997 mercedes benz slk 230
Car Radio Battery Constant 12v+ Wire: Red/Green
Car Radio Accessory Switched 12v+ Wire: Pink/Yellow/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Gray/Blue
Car Stereo Antenna Trigger Wire: Blue/White
Car Stereo Amplifier Location: Under right footwell carpet.
Car Audio Front Speakers Size: N/A
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/Brown
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
pls rate
Dec 13, 2009 | 1997 Mercedes-Benz Mercedes Benz Sl Class
Need stereo wiring diagram
i need speaker wire colors for a 1988 mercedes benz 300sel
Dec 07, 2007 | Car Audio & Video
Car Audio & Video Logo
362 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
