Hey here are somethings you need to do.
1) Open internet explorer -> Tools-> Internet options ->General -> Browsing History -> Delete -> Check all boxes -> Delete. (IE 8, The process is quite similar in other browsers as well)
2)For XP
Start-> Run-> type temp-> Ok-> Select all-> (Shift +Delete)
For vista
Start-> Start Search-> type temp-> Ok-> Select all-> (Shift +Delete)
3) For XP
Start-> Run -> type %temp%-> Ok-> Select all -> (shift+delete)
For Vista
Start-> Start Search-> type %temp%-> Ok-> Select all-> (Shift +Delete)
4) Turn off laptop, Remove battery , Remove AC adapter, Press power button for 2 minutes. Put both back on. Turn on laptop.
5) Run virus scan and check for malware and other virus related issues. If anything is found delete the infected files.
6)
For XP
Go to Control Panel-> Add and remove programs-> Remove all unnecessary softwares
For Vista
Go to Control Panel-> programs-> Installed Progams->Remove all unnecessary softwares
7)
For XP
Run-> msconfig-> Startup->Disable all
For Vista
Start search -> msconfig -> Startup -> Disable all
8)
Check for the system RAM. If your laptop has 2 memory cards installed. One might have failed. So try to remove it and fix it back again and check
9)
Get the fan checked.?
