Question about Hitachi P50T501 50 in. Plasma HDTV
Hi,i have an hitatchi p50t501 plasma and i just put in on and everything was fine,then i put it on video 1 to put on direct tv, then i put it back on cable left the room and the tv light keeps blinking blue and no picture, i unplugged the set waited 30 seconds the red light went on meaning the power is off then i put the power on with the remote the blue light went back on but did not make the clicking noise that it usually does,i started to hear the station then nothing and the blue light started flashing 4 times then pause then 4 times then pause etc... please help!!!!!thanks, paul
Posted by wohc61 on
Anonymous
    Problem Solver:
  • 9 Answers
The Blue Blinking Light Hitachi.
When the light blinks 4 times it means you can possibly have 4 problems with your plasma.
1. X-Sus
2. Y-Sus
3. Power Supply
4. Sdr U or D
A good way to determine if you can fix this problem yourself is if you can build a PC. If you cant this can cost you upwards of 600$ to fix.
First get a flat area and lay a soft blanket down and lay your TV down so the back is up. Then goto your PC and goto Google and type "P50T501 Service Manual .PDF" you can buy it or if you look hard enough you can get it for free. Next in the service manual it will have a diagram of the Circuit Boards and their locations. Take the back off your Plasma and check the 4 boards. Look for burn marks, cracks, smoke mark. Take your time and look closely. When you find the broken boards unplug it and take the part number and find the replacement online. Plug it in and you should be good to go.
When i had 4 blinking lights i had to change my SDR U and D boards. They cost 100's a piece for Refurbished boards. Keep in mind im a contractor not a techno geek, and i was able to diagnose and fix my problem rather easy.
Posted on Aug 26, 2009
I have a hitachi p50t501 plasma sound wnt go up or down stuck where its at but the volume bar goes up or down but volume wont change
This means that the logic control is working on the controller unit but the audio section - audio amplifier drivers - are not responding.
So it seems that the audio preamp section is faulty and it can be confirmed only if signal test or a voltage check is done and traced.
The changes from the logic control must be traced to confirm the section.
Nov 12, 2011 | Hitachi P50T501 50 in. Plasma HDTV
Power button on p50t501 not wsorking
Its probably busted it can be replaced but not really worth it just use a remote
Sep 25, 2011 | Hitachi P50T501 50 in. Plasma HDTV
Where do i find a lower SDR-D board for a 2007 HITACHI p50t501 please help TY
www.shopjimmy.com or have a repair tech fix the board itself. The buffer boards are getting harder and harder to find.
Aug 13, 2011 | Hitachi P50T501 50 in. Plasma HDTV
Good day the problem of tv is that if there is audio but no picture
hello,
you need to open the back cover of the television to check for bad component,
check for( q009)if if it is open circuited, then replace for a new one...
Take care
Jun 02, 2010 | Hitachi P50T501 50 in. Plasma HDTV
I have a Hitachi P50T501 plasma tv. The screen went blank while watching it. We have been unable to watch tv or dvds. The power light is blue.
Tries unplug,replug about 1 hour later,if doesn't work,than Ur main video backlight board it dead,must replaced.
Nov 20, 2009 | Hitachi P50T501 50 in. Plasma HDTV
Hitachi P50T501 plasma tv powered off.
Your TV has a bad power supply on it. Ask the repair service technician to fix your tv.
Jul 27, 2009 | Hitachi P50T501 50 in. Plasma HDTV
Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Feb 28, 2008 | Televison & Video
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
Hitatchi tv problem
A fuse has probably blown inside the TV, I had something similar with a panasonic TV a number of years ago. Open the back up and use a continuity tester across your fuses till you find the right one...................dont forget to unplug it first !!
Dec 10, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Transparent horizontal bar
disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .
May 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Hitachi P50T501 50 in. Plasma HDTV Logo
1,241 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
