Hi
It sounds like the hard drive in the unit is either faulty or the contents are corrupt, You can either contact archos and send the unit to them for repair or you can try reinstalling the firmware into it yourself.
1 go to Archos website and download latest firmware and save on your pc
2 turn it on and select repair - unit not connected to pc
3 connect it to pc and wait until pc recognises it
4 copy firmware from pc and paste it to the root directory. (first directory, the root)
5 press done on the unit.
it should work normally. If it doesn't its very likely a faulty hard drive.
http://www.archos.com/
Hi
Thanks for using FixYa. Try and reset your archos 704 by pressing the power ON/OFF button for more than 15 seconds. You can also use the master reset function by removing the battery & then press the master reset button.
Note: Resetting your Archos will not erase any data from your device.
Also try Recovery mode-- Press the button to turn on your device. Immediately press and hold the until the Recovery mode screen appears.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
If you have already tried everything then the possible way to remove the error is getting this repaired/replaced by a auth. repair center so to avoid future issues.
Thanks
Rylee
Please click on this link and select your city, then you'll get the local repair shops list with their contact nos#
Repair Shops In NewYork
Thanks
Rylee
Did you even clicked on the link I sent you??
Rylee
LIKE I SAID I TRIED ALL RESETS ALL THE ONES YOU SUGUSTEDIS THERE ANY PROGRAMS I CAN GET ON COMP. TO FORCE IT UP
WHERE DO I FIND REPAIR SHOPS IN WESTERN NY
i provided all the information i have and i think the information from the other guy was a cop out
I LIKE YOUR IDEA ONE PROBLEM THE FIRMWARE HAS A AOS ATACHED TO IT AND WINDOWS WON`T ACKOWAGE IT IS THERE A WAY TO GET AROUND THIS
