Question about Uniden Lands Phones
My uniden has two greeting options, A default and a custom greeting, but I'd like to tweak/change the default message to suit my need (for my business purpose). How do I do this?
Posted by Maggie on
Cathann Smith
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
If you need to change the greeting then you should use custom greeting to suit your needs. Go to Menu and then settings for answering system go to greetings and it should give you instruction.
Posted on Jul 01, 2019
5 Related Answers
kehalim
Michael Lugassy
  • 55 Answers
SOURCE: avoiding the greeting message
Why not record a 1 second of silence instead of the standard greetings and have them "jump" straight to leaving a message.
Posted on Oct 23, 2007
One Wire
Dean Pitts
  • 126 Answers
SOURCE: Uniden Digital Answering Machine / Change Greeting
Here is a link to the pdf format of the tru8885 owners manual:
http://www.uniden.com/pdf/tru8885om.pdf
Posted on Jan 26, 2008
Vit Avaya BP
Vitaly Kagan
  • 211 Answers
SOURCE: I need to change the main office greeting on partner phone
Login to your administrative mailbox. Its option number 3.
Posted on Mar 18, 2009
Cabanaboyz
Cabanaboyz
  • 122 Answers
SOURCE: how do I change the voice mail greeting on my Avaya Partner 18 ?
I'm kinda new here, but why doesn't anybody say WHAT SYSTEM THEY HAVE????? It's kind of like saying I got a GM car. Uh..... Corvette or is it a Lumina?
ANYWAY, I'm presuming a Partner.
You better hope the previous guys left you the password.
Go to a station, dial 777 to get to the VM.
99# should prompt you for the password. Try 1234 or 1111.
If you get in, just listen for the prompts to guide you.
Good Luck
Posted on May 03, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: We have a business panasonic
Assuming you dial 165 to get to the voice mail system (a TVS type box) you press #6 * 998. You better know the password if it asks and you need to know where the greeting was recorded. It sits either in a Custom Service box (1-100) or a Company Greeting (1-32).
I'd be hoping that someone left a TVS Installation and Programming manual with cheat notes lying around. If not, there's a way into the TVS via a terminal program and the DB-9 serial connector on the box. That will let you read the database.
Your Panasonic installer/dealer might have the passwords and setup in their records.
Carl
Posted on Jun 29, 2011
Setting up answering machine for UnidenDECT 6.0
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Apr 18, 2015 | Uniden DECT 6.0 Cordless Phone
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
Aug 11, 2014 | Uniden DECT 6.0 Cordless Phone
Our company uses the Panasonic KX-T7730 phone system. When I change the answering message, it is immediately followed by an outdated message. Changing the message works, but the old message still fo
When we set up a Panasonic voice mail system, you have a menu that plays. Usually, there is a Company Greeting, then a Custom Greeting. They are changed from mailbox 998 option 5 then 1 or 3 depending on which greeting you want to change.
Of course, you may not have a TVA or TVx voice mail system, but I'm guessing that's what you have. In all cases, the Company greeting plays in front of the Custom greeting. By default in a TVA it's probably both greetings 1. You can log into the system and play them without changing them to verify what's where.
Carl
Feb 10, 2012 | Panasonic KX-T7730 Corded Phone
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Hi there, my business uses Panasonic KX-T7431 Digital Super Hybrid System and we have several lines. when nobody is available to take the call it goes directly to a company message stating are names...
The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
Dec 28, 2010 | Panasonic KX-T7431 Corded Phone
How to change voicemail message. I have no manual. Thanks
I just looked up how to change it....press the mute button, the scroll left or right to reach recordpersonal message and press the menu key. when you're done recording press the 5 key to end it. Works for my Uniden DECT 6.0
Aug 12, 2009 | Uniden DECT 6.0 Cordless Phone ID
Need to change my outgoing message on my uniden powermax DCT648-2
PRESS AND HOLD THE "GREET" OR "GREETING" BUTTON ON THE BASE UNITL YOU HEAR A VOICE THAT WILL SAY RECORD GREETING, START RECORDING THEN PRESS IT AGAN TO PLAY IT BACK TO YOU.
May 07, 2009 | Uniden 2.4 GHz Cordless Phone System
Want to change the greeting when a call comes in.
Call your voicemail box like you're checking your messages. Continue listening to the prompts until you hear an option to change user options or personal options. Under this menu should be an option to change your personal greeting. Follow the prompts to re-record and save and there you go. If you have any problems, contact your customer service as this is the method to change your personal greeting.
Sep 17, 2008 | Uniden Cell Phones
Avoiding the greeting message
Oct 23, 2007 | Uniden TRU8885 Digital Answering Machine
Lands Phones Logo
140 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
