SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
ngafm
please give me a rating before you sign off!
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water
shut-off valve (located under the sink) is open. If you get water to
the dishwasher, but there is still no water inside during the fill
cycle, the problem might be with a faulty water valve (located at
the bottom of the dishwasher, behind the kick panel, on either
side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This
could be caused by a partially closed water shut-off valve (located
under the sink), or a faulty dishwasher water valve (located at the
bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher.
Make sure there is no debris blocking the holes inside each spray
arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees
Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to
both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the
dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
There are a few out there.
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
