Sharp 32L-S500 TV Logo
Posted on Aug 15, 2009
Acessing menu without remote
Help with accessing menu without remote
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4380
Points
22
A) Look for a menu button somewhere on the tv itself .. Usually volume or channel buttons serve as up and down, etc..
OR
B) Go to electronics store and buy a universal remote $10-$20 and program it for your tv.
1helpful
HTR-5750: How to access menu without remote control?
Unfortunately, you need the remote or a universal remote which matches the original remote to access the menus. The manual for the HTR-5750 is available here: https://usa.yamaha.com/files/download/other_assets/5/319575/HTR_5750_5740.PDF Amazon lists a few vendors with an equivalent remote.
I wish that I had better news for you.
tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
I have a panasonic PV-M2768 and i don't have the original remote. I have a RCA universal RCR312W. I have tried all codes I can find. (interesting side note: the remote manual says to enter a 4 digit...
Universal remotes are a very limited devices for a replacement of a remote.U get the tv for power on/off,channel up/down and volume up/down,the basic that all u will ever get it out of the universal remote.No button said Menu on the front of the tv for acessing tv Menu,than sorry no combination of buttons,will help u to access the tv Menu.Sorry,but now,u must buy the tv original remote.Try website like Remotes.com to buy an original remote.
No factory remote i can't acess to the menu system
Most televisions and monitors have a menu button next to the power, volume, and channel buttons on the face, top, or side of the set. It can be a pain but you can usually press the menu button to bring the menu up and then select and change settings by pressing menu again to choose a setting and using the channel and/or volume up and down buttons to raise or lower the setting. The exact function varies based on the set so you may need to fiddle around a bit. Unfortunately some sets do require the remote to perform some functions.
How do you acess game without your remote
first question. you need a remote to get to the inputs on the tv. some reason they made it like that. get universal remote and try it if don't work return and try another brand ect.
second question.
try another code maybe or jsut return it and try another remote. the rca 15-2115 5 device remote i have workes with the "A/B tv?vcr". on the origional remote that comes with the tv there are actually 2 buttons. one is called "input" and the other is "game". the only difference between them is turns the game mode on and off in the picture menu. i really don't like haveing "game mode" on because it makes the picture looks bad to me. you can turn it off in the picture menu easy.
1helpful
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
2answers
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
1helpful
No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
2helpful
Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Menu
to acess the menu push the channel up button and the volume up button on the front panel or the channel down and the volume down.and the menu will appear.but you can get the originald remote at www.partstore.com good luck
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
