Look for you answer here:
https://www.manualslib.com/k/kenwood+kdc-mpv622.html
SOURCE: kenwood KDC-MP5028
with the unit in standby, press the menu key, use the joystick control to choose aux, and set the aux option to "on"...then press menu again to save...when you next switch on the unit, using the SRC button you can cycle through the available options...cd - tuner - aux..etc etc
SOURCE: Cannot Find Aux On Kenwood KDC W3037A
You have to ENABLE to AUX source thru the settings menu.
Users manual is HERE.
Best of Luck.
Please RATE my solution BELOW.
SOURCE: hey jeff about the kenwood
In standby you have to hold menu doen untill menu appears on screen, Scroll to aux and turn it on :)
Don
SOURCE: aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
SOURCE: ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
