Model Number MSD2758 GEW WITH AUTOMATIC ICE AND WATER DISPENSE - Rrefrigerator portion is not working at all. Freezer was working well till yesterday but seems it's going down too
It sounds like your refrigerant is leaking out. Without proper test gear you can't confirm this, but the first thing that happens is it stops cooling.
You need to call out a qualified refrigeration engineer to check it. You may be able to see oil at the back of the fridge around the leaking joint. Do not leave it switched on and running if you have a leak. Have you smelt anything unusual recently? The gas isn't dangerous in the quantities you would have from a leak unless it is exposed to a naked flame. Then it breaks down into a gas similar to mustard gas which was used during the first world war. If you didn't notice the smell of the refrigerant gas, you won't miss it if it is around a naked flame.
