Computers & Internet Logo
[email protected] Posted on Jun 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tom tom GPS sat nav 400 display brightness dims down over One hour, until it is hard to see. Audio Directions Still Working OK
Don A
Level 3:
  • Hard Master 4,495 Answers
  • Posted on Aug 01, 2023
Don A
Hard Master
Level 3:
Answers
4495
Questions
5
Helped
1336265
Points
25824
Http://download.tomtom.com/open/manuals/rider_400_40/html/en-gb/index.htm#Display.htm
There is a setting in the device that changes to night time colors automatically when it gets dark if selected. The display controls allow adjustment of brightness and change of colors. If operating by battery alone, some battery saving feature may be at work. Tom Tom support might be able to answer that question. https://help.tomtom.com/hc/en-us/articles/360013898180-Extending-the-battery-life-of-your-navigation-device
https://help.tomtom.com/hc/en-gb/articles/360013901180-Changing-night-day-colours-on-your-navigation-device
http://download.tomtom.com/open/manuals/rider_400_40/html/en-gb/index.htm#Appearance-MASTER.htm
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jan 31, 2009
SOURCE: Tom tom gps speakers not working.
I have had the same problem. I bought my gps used.I soon found out sound would not come out of the gps untill I taped on the back of the gps. I solved my problem. The voice coil in the speaker becomes detached. Their are 4 screws in the back of the gps once you open up the gps the speaker is attached to the back of the inside of the gps. You have to carefully detach the speaker from the back of the gps ( I used a small flat head screw driver like one from a eye glass repair kit ) then press lightly on the center of the speaker wile the gps is trying to talk (hopefully when you do this the speaker will make noise). I stacked 2 dimes in the center of the housing of the speaker then reatached the speaker to the housing thus sandwitching the 2 dimes between the housing and the center of the speaker. For my unit this put enough pressure on the center of the speaker for the system to work. Then I reassembled the gps. It was about 4 or 5 months ago and the speaker still works fine. Some times the easy solution works just fine.
Anonymous
  • Posted on Apr 23, 2009
SOURCE: Mobile phone won't connect to Tom Tom go 540 live
Hi, I got round this problem by pressing and holding the ON/OFF button for 15 seconds untill system reboots. Then reconnect mobile,if not delete mobile and repeat process.
Anonymous
  • Posted on Sep 23, 2009
SOURCE: how can I change battery on my tom tom go 730 sat
How do I change the battery of my Tom Tom 730
Anonymous
  • 243 Answers
  • Posted on Feb 18, 2010
SOURCE: my sat nav tom tom go 530 won't connect to my
hi, make sure you installed the latest verion of tomtomhome. you can collect it at tomtom.com good luck
Testimonial: "very helpful, thanks a lot mate."
Anonymous
  • 243 Answers
  • Posted on Feb 19, 2010
SOURCE: my tom tom sat nav wont turn on even when plugged
hi try a soft reset, first make sure your battery is full. if you use a sd card, remove it. push reset button on bottomside of your tomtom, its in the middle next to "reset" push it with a small pin, paperclip or something, for at least 15 seconds. after that push on/off button for minimum 5 seconds. if used push back sd card. good luck
9helpful
How can i update my guide sat nav
If the maps are on an sd card you may be able to put tom tom on but as for updates myguide no longer exist and so don't provide updates. Mine still works fine and any roads that have been built that don't appear on the sat nav i have managed anyway.
My tom tom sat nav will not turn on the green light works but no screen lights up
Try holding the button down for several seconds, as well try unplugging it until it dies then chargeing it.
MY TOM TOM WILL NOT START
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
6helpful
2answers
Tom Tom sat nav takes ages to get a GPS signal now.
Think I have sorted the problem out. I read some of your readers' solutions and it was mentioned that it may be advisable to log onto the GPS update. So, I installed my disc which came with the pack and followed the instructions to download the GPS update (and also took the opportunity to download other updates which took some time). Anyway, used the sat nav this morning and so far, it appears to be working normally now and the signal comes on in seconds!
2answers
Apr 05, 2009 • GPS
Tom Tom sat nav language
There should be a language change option in one of the Tom Tom menu`s
Tom tom 300 sat nav
Go to the preferences section and you will see apromot that shows you how to fix that!
Jazzman02
2answers
Voice not working on garmin sat nav
garmin has alot of issues the best thing you can do is go buy a tom tom they work alot better and dont have the issue garmin has
No audio directions
try doing a hard reset underneath the sat nav is a small slide reset remove sd card first, reinsert and switch on, good luck
Sat nav tomtom 910
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Top Hard Computers & Internet Experts
Jean Thiebaux
NOEL
NOEL
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
