Televison & Video Logo
Question about Alba Televison & Video
I have an Alba TV 32 inch screen. The sound comes on for a few minutes when it is switched on but soon the sound cuts off. I have to switch off for a few minutes before I get sound again.
Posted by Richard Amoah on
5 Related Answers
Anonymous
  • 85 Answers
SOURCE: 32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
Posted on Jun 13, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: 32'' LG TV no picture or sound
You may have lost the main controller board, but you should at least check the main power supply first for any signs of bad components such as capacitors. Also check the DC voltage reading on the connectro if they are labeled with voltage indicators.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 10, 2009
Testimonial: "Thank you your advice has been very helpful"
COLIN
  • 182 Answers
SOURCE: Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Posted on Jun 11, 2010
joedirty
joedirty
  • 158 Answers
SOURCE: I have an AVOL ALT3213M TV 32
Yes, I had the same problem and it was the invertor board that controls the lamps .I bet ya that's your problem.Hard to locate parts for these lcd's.If you find a supplier please post.Have fun locating parts. It took me 2 weeks to locate one.
Posted on Jun 19, 2010
Anonymous
SOURCE: murphy 32 " tv/dvd when switched on screen comes
INVETER BOARD IS FAULTY
Posted on Aug 06, 2012
1helpful
Why does the volume on my tv keep cutting off
Hi Daniel,
The most probable reason for this problem is the electrolytic capacitors in the sound section. A few of them need to be replaced. Please do not forget to check the speakers also.
I have an alba 32inch tv and the sound keeps turning off we have to then switch tell off for a minute to get sound back but the sound is gone again in 5 min only 2 years old
sound like there is a over heat / or failure of some circuits
32 inch are quite cheap now, so it maybe something you should re-place,
or flog to a 2nd hand shop if it last long enough to sell during test
1helpful
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
1helpful
ALBA 32 INCH FLATSCREEN AFTER 10 SECONDS SCREEN GOES BLACK BUT SOUND IS FINE?
Check for dust blocking the air vents as this will cause the TV to over heat but I would expect it to take longer than 10 seconds.
Philip 29PT6021 switched off suddenly
Capacitors problem in vertical circuit
Dell 32 inch LCD Tv volume and menue problems
your main board is not communicating with the tv. it may be on the breaks of going bad, or simply needs a firmware update. questions, email me
32 INCH tv
Plasma tv
Sounds like a Capacitor on the Main PCB
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
1helpful
3answers
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
