Question about Moen & One Handle Tub & Shower Faucet
We installed two new single handle shower faucets with both hot and cold supply lines pressurized to each of the faucets. The problem is that no hot water will come out of either faucets. Their seems to be plenty of hot water pressure up to the faucets but none comes out. Could we have messed up in the installation? Thanks, Ben
Posted by ben425 on
Mark Chambers
Sounds like the valve is defective. The supply to the stems was not bored out at the factory giving you a valve that is essentially pretty on the outside and solid on the inside. To test it, uninstall the valve. Remove the stems. Then try running a pipe cleaner though the valve from the supply side and see if it stops before the stem.
Posted on Aug 16, 2009
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Sterling shower faucet
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Apr 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Moen & One Handle Tub & Shower Faucet  Logo
226 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
