Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
D-link WBR-1310 router and Playstation 3 online games
I am having trouble joining games in Fat princess. On PS3's website it claims to use
  • TCP Ports: 80, 443, 5223
  • UDP Ports: 3478, 3479, 3658
for the playstation network. My question is where do you input these numbers, i have been to application rules and i am not sure which is for the trigger port and the firewall port. Any help would be fantastic!
Posted by dookiew on
Jeff Sterrett
    Scholar:
  • 108 Answers
This site can walk you through the process....
https://portforward.com/d-link/wbr-1310/
Posted on Sep 01, 2017
5 Related Answers
Anonymous
SOURCE: cannot access the WBR-1310 webpage
that doesn't work! should technically work, but the D-link 1310 sucks!!!!
Posted on Apr 06, 2008
Cloudbooks
  • 163 Answers
SOURCE: free download of d-link wbr-1310
just click below link and select your country code you can download
the installation guide for free
http://support.dlink.com/products/revision.asp
Posted on Dec 18, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: D-LINK WBR 1310 ROUTER
Go the router setup page, 192.168.0.1, type admin as the user name and password as the password (default, if you have changed these use your login info).
Then on the wireless page change the SSID (router name).
You can also add a security key on this page.
http://support.dlink.com/emulators/wbr1310_revA/wireless.htm
more info from D-Link:
http://www.dlink.com/products/support.asp?pid=474&pv=96&sec=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 12, 2009
Anonymous
  • 611 Answers
SOURCE: dlink wbr-1310 quick installation guide
http://www.dlink-india.com/products/Product_temp.aspx?id=9,437
download it
Posted on Apr 17, 2009
Anonymous
  • 56 Answers
SOURCE: how to install d link WBR 310
Go here and get the infor needed, guides etc....
http://www.dlink.com.ph/support/supportdl.asp?pid=602
Posted on Sep 16, 2009
The NAT is on 3 and it needs to be 2 for the PS3 to work online properly. i have a Zyxel_41C.
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 14, 2011 | Zyxel P660HW-D1 Router
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
I need help changing my nat settings from strict to open for my ps3, i have a bt home hub router, and my upnp is enabled, is there anything else i can do???
PS3
You will have to open the following ports in your BT router
Make sure the firewall is disabled in the Router
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 02, 2011 | Sony PlayStation 3 Slim
Says i have nat3 network setting connect problem for players
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Well i join a game i play like 2 minutes then it sais u have been disconected from the host i need help plz
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Dec 02, 2010 | Ubi Soft Assassins Creed: Brotherhood
Error 80028e02 cant play online
PS3 error 80028E02 can be caused by different source of network showcase270.jpgblockages. If you happened to be in a filtered network, that's your most probable reason why your PS3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your PS3 to connect online.
If the modem or router is blocking your connection then it can be fixed by opening some ports
you will have to call your computer vendor to open the ports
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Nov 24, 2010 | Activision Call of Duty Black Ops
Why is my NAT type strict on my ps3?
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
Wot is nat type and why dose it keep failing
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Nov 02, 2010 | Sony Playstation 3 (PS3) Console
How do i change my nat,mine says strict
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
make sure all ports are open on the router
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
451 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
