? 0:39 www.youtube.com/watch?v=W_og12QJqm8 May 8, 2010 - Uploaded by maxicheong
Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Humming sound might be igniter trying to fire up but fails.
It might be eitther bad igniter or bad gas valve.
Please kindly let me know if you need more info. I am always here to help
Good Luck
there is power to my GE gas dryer but it wont start
