Amana AGR5715QDS Gas Kitchen Range Logo
Posted on Aug 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a code on sceen 5a6 what dose that mean
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Aug 15, 2009
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735444
Points
22413
What's probably being displayed is actually "Sab". This is an indication that the range is in "Sabbath Mode". This mode is set for those religions that honor the sabbath and disables the oven for about 72 hours. Unplugging the range will not clear this. It can sometimes be set accidentally following a power outage or inadvertently hitting the wrong button on the control panel.
If the model number you have this listed under is correct, you can cancel Sabbath Mode by pressing and holding the "CLOCK" button on the control panel for 5 seconds. If you refer to your Owner's Manual the instructions are listed under the Oven features section.
If you do not have a manual, you can go to managemyhome.com and download one for FREE.
If you have any questions, please let me know. If the model number is incorrect, please post back with the correct model number so that I may provide you with better assistance. I hope you find this information helpful.
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
Skip,
The fact that the display is 'ON' confirms you have power.
The displayed info probably is a 'code' for a fault/problem, but you did not provide a brand nor a model. Even if you had, odds are I do not have access to the list of codes & their meanings.
Try unplugging the plug from the wall receptacle. If you cannot reach the power cord next option would be locate the circuit breaker (single pole) which HOPEFULLY is labeled. Either way, try removing / turning OFF power for at least 10-20 seconds! The control's microprocessor may be locked up due to a very short power interruption.
If that does not reset it, I would call service or the manufacture. You can TRY requesting help over the phone FIRST! Good LUCK
Mrs. Robin Adair-Weber, CET
2answers
Maytag electric stove has an error code of 5A6. What does this mean?
It is not 5a6... it is Sab... (Sabbath mode)
Hello Susan Krim,
If you do not have your MODEL NUMBER
(nothing came through with your question)...
Find your original OWNERS MANUAL...
and look up how to DEACTIVATE the SABBATH feature...
ELSE...
Get the model number and go to my
favorite FREE manual site...
ManualsLib Makes it easy to find manuals online
Hope this helps... Next week too...
Carnac the Magnificent
1helpful
2answers
What does this code mean
Its 5A6..... You have enter the oven into sabbath mode when try to set the clock. To exit sabbath mode press and hold the clock button for 10-15 seconds. When you set the clock yous press the clock button but dont hold it in.
6helpful
2answers
WENT TO SET CLOCK, SOMEHOW DIS-TURBED THE CONTROL BOARD, IT IS LOCKED, READS 5A6, CAN I UNLOCK IT?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab" or "5A6.
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Mar 13, 2011 • Ovens
3helpful
Code came up when trying to set tim code " 5A6 "
The error your range is displaying is actually "SAB", which means it has inadvertently been set on "Sabbath Mode". This mode enables certain religious faiths to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number is correct, somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off. According to page 17 of the Owner's Manual, to cancel the Sabbath Mode, you need to press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
2answers
The sceen is black but wen u press the power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
14helpful
2answers
What is error code 5A6?
Hold the clock key for several seconds and it resets the kitchen range.
Thanks for contacting fixya.com
61helpful
7answers
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Top Amana Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
