Sony NW-E002 MP3 Player Logo
Posted on Aug 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer doesn't recognize my sony NW-E002F.
The device start charging right away but I does not apply itself as a new hardwear. I can't even see it in aSonic Stage, program for transfering music on this device.
What should I do?
Thanks
  • furunce Aug 16, 2009
    I tried the other ports, and starting from the off position but it's not working. It does charge, and it plays music when it's disconnected but I still can't see it on my computer, change music on it, etc.
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Aug 15, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
31018
Points
317
Try a different USB port on the computer. Preferably one directly in the computer (not on an external device).
Sometimes the computer has a hard time assigning it a drive letter because other devices might be using a letter the drive thinks it has to have. You can also try plugging the drive into a usb port and starting the computer from the off position.
2answers
My SONY NW-E002F mp3 walkman, 512 mb tells me
1.reset device.remove battery.and try again.2.clean MMC of dirty. good luck
Computer does not recognize the player
Hi jowik,
Most websites are saying that this is a model Sony no longer supports or sells at the moment. The software required is SonicStage 3.0, same as you're probably using. However, it is more of a problem that the device isn't being recognized at all. Have you tried connecting up to any other computer? If no computer can recognize it (which shouldn't happen, but anyway) then there's something wrong with the player itself. When you connect, check for loose connections, and never use more than one USB extension at once. Many people use an extension of their own plus the one provided by Sony, and they have the same problem that the computer can't recognise the player.
Using the standard sony lead to attach to computer and its not charging or even being recognised as anything being plugged in. help?
Hello
Well, if the computer does not recognize that anything has been plugged in, there might be a fault with the cable itself, or the connection unit of the device you want to access. I would try plugging it into one of the other USB ports at the back of the pc and see if the computer responds differently to the insertion of a cable. Hope this can help.
Best regards
Andrea
1helpful
My mp3 NW-E002F dont work it says format error but it works on FM pls help me how to fix it
hello sir please describe your problem tell me when you trying it to format ...it is saying format error or when you plug the device into the computer
113helpful
3answers
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
2answers
Own an mp3 sony walkman NW-E002f need help getting downld songs to play or where located in player
to make sure they work go to start then find computer click it it sould bring up device that are on the computer then click on it. It will show all the songs on the player or any information.
2answers
No database
no database pour sony DIGITAL MUSIC PLAYER S/N 5313776 NW-E002F
Sony walkman nw-s205f problems......
if you still have the receipt i suggest that you try to exchange it.I had a simular problem with mine and it was a manufacturers flaw
2answers
Problem with sonicstage software
Sony NW-E002F (512MB) MP3 player
My computer cannot detect this device. Do you have any solution on this problem.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
