Computers & Internet Logo
Posted on Aug 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a BIOS upgrade for Motherboard:VT8367-8233 AMD Athlon XP2000+ 1.67 Ghz. BIOS ID:03/27/2002-VT8367-8233-6A6LVE1CC-00-None BIOS OEM:K7VTA3V3 Ver:3.0 03/27/2002 - 6.00 PG Chipset:VIA 82C3099 rev 0 SuperIO:ITE 8705/SiS 950 rev 2 at port 002E Any ideas where to get an updated BIOS? Main reason is to try and use a SATA 500 GB HD. I see the Drive in the Raid sw but cannot access the drive. I thought maybe the BIOS is too old? Any suggestion would be welcome.
Anonymous
Level 3:
Master:
Sergeant:
  • Master 460 Answers
  • Posted on Aug 20, 2009
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
460
Questions
Helped
134826
Points
1144
It is not supported for this MBD.
What is the voltages , vcore etc for normal settings of a amd 4600+
Just got to into your Bios and reset the factory settings and It will reset the changes you may have made.
1helpful
CPU (processor) speed dropped to 1.09GHZ
Go back into the Bios and change the settings back. If this does not correct the issue you may have another issue. If this is a laptop you can reset the bios by locating the Bios reset switch, usually appears as a pin hole on the bottom of the computer, if this is a desktop then you need to use the Bios Reset jumper on the motherboard. It sounds as thought Windows is not reading the CPU type and speed correctly so you need to undo the change you made to get it back up to speed.
Driver
Thats a prosessor, theres just one driver for that, and still its not a must have.
now if its a motherboard that you need drivers for, now just the processor, go over here and select the right motherboard, you will get the drivers you need.
http://support.asus.com/download/download.aspx
and you can get a prosessor driver from here for AMD
http://support.amd.com/us/Pages/drivers.aspx
Let me know how that goes.
Thanks,
Ekse
3answers
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Issues in Upgrading BIOS
Actually, your motherboard is a GA-7ZMMH, which we were lucky enough to see in the BIOS ID string. You can find the latest BIOS's from Gigabyte's website at: http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1315 It looks like you're on the F5 rev. I would suggest the F10 rev, and only go to the F11b rev if you need the support for the Athlon XP 2600+. If you are not upgrading your BIOS for CPU support, or you do not need to support a CPU faster than the Athlon XP 2200+, then go with the F10 rev.
2answers
1helpful
2answers
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Grand Canyon Tech
Grand Canyon Tech
