SanDisk Sansa e260 MP3 Player Logo
Question about SanDisk Sansa e260 MP3 Player
Hi! My Sansa e260 won't turn on. It charges
Hi! My Sansa e260 won't turn on. It charges and i can add/delete music when it's plugged into my computer, but as soon as i unplug it it turns off and will not turn back on. What do i do????
Posted by kenn2000 on
Anonymous
    President:
  • 392 Answers
Try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Posted on Aug 15, 2009
1helpful
2answers
I cannot delete songs from Sansa E260
Ok, Sansa made it a little difficult this time,
"Connect your player, of course. Go to "My Computer" > "Sansa e260". There are hidden files. To unhide go to "Tools" (located on the menu bar) > "Folder Options..." > hit the "View" tab > select "Show hidden files and folders". You will see more folders to appear in a faded color. Click on the "MUSIC" folder. Click on the artist, then album then select the song, right click and down to delete." --Yahoo Answers
1helpful
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
My sansa e260 isnt turning on
Well for starters, clear some memory. It sounds like the player is trying to turn on but failing as there is not enough free flash memory for it to use in a RAM like fashion. If youre using windows enable the view of hidden files folders. [Start> Control Panel> Appearence and Themes>Folder Options then browse through the tabs until you find a list which has the option "show hidden files and folders". Then plug in your e260 and go into the larger removeable drive. Then go into the folder "VIDEO" or "PICTURES" or "MUSIC and delete some files. Then once you have deleted at least 100MB, unplug and restart the player. This should fix your problem if it doesnt. Consider formatting the removeable disc, or updating the firmware. [However take extreme caution with formatting the disk to ensure that it does not contain the program files needed to run the player.
2answers
How do i delete videos off of sansa e260(4Gb)
Do this.
Go to computer
And see the removable disk.
Locate the one that its attached to
Right click
Format it
It should work.
1helpful
4answers
Sandisk sansa e260 reset?
Plug it into the usb port. The Sansa 260 will show up as the next drive letter. Using the right mouse button click on the drive latter and select format. This will will format your Sansa 260. The operating system files will still be there but all of your music, movies, voice recordings, etc... will be deleted.
Cant add/delete songs
it is just re-reading the songs
Top SanDisk Audio Players & Recorders Experts
Steve Nordquist
Steve Nordquist
W.L.
Marvin
Marvin
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
