SOURCE: 2420 Gigaset call waiting answering machine
Make sure the answering machine is turned on for both lines. To check settings: Scroll, using BACK and FWD, to desired setting. 1. Press MENU 2. Scroll to "ANSWERING SYSTEM MENU" then press SELECT 3. Scroll to "LINE 1 SETTINGS" and press SELECT 4. Scroll to "ANSWERING SYSTEM ON/OFF." Check to see if it is set to "ON," as this is the default setting. 5. Exit MENU and Repeat steps 1 thru 4 for LINE 2 SETTINGS. I don't know if you have Acrobat Reader for .pdf files but below is a link to the owner's manual for this phone. If you can, download and look at the bottom of page 79 of 116 for more help. http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052870.pdf Good luck.
SOURCE: how to set message for answering machine lost directions
hi is this your phone here http://evaluezone.com/dxi986-2.html
also you can get the manual from here as well .
or a search on there web site Uniden | A World Without Wires
may find the right manual .
riz.
SOURCE: setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
SOURCE: number of rings
two rings means it has message, erase the message to increase the number of rings to like four
SOURCE: Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
