Question about Lexar FireFly 2GB USB 2.0 JumpDrive
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
Posted by camillacalla on
Anonymous
    New Friend:
If you have files on the stick and it asks for formatting, the file system is probably damaged. Try a quick format on the USB-stick. DO NOT save any files to the stick. Use a file recover tool on it, like example: Piriform's Recuva. Use the Deep Scan function.
Posted on Aug 08, 2010
Anonymous
  • 336 Answers
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Posted on Aug 14, 2009
How to format Lexar JD USB
Insert the flash drive in a USB slot and see what drive letter gets assigned to it. Right click on the new drive letter and select format from the drop down menu. Follow the directions on the next screen to format the drive.
Aug 23, 2014 | Lexar FireFly 2GB USB 2.0 JumpDrive
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
Mar 03, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I deleted all the viewable files and folders on my lexar firefly jumpdrive, but it says that i still have almost all my memory used up. how can I clear it?
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
Jan 05, 2010 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Usb keeps ask for formatting why? please
On brand new USB disks sometimes, from value companies, they may require a formatting, I assume it is a new USB memory stick, allow it to format to "NTFS" if that is not an option let it format to "FAT32" Hope this helps.
Nov 04, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
Oct 20, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I have a Microsoft Excel file saved on a thumb drive that won't open. All the others will. I get, "file format is invalid"
It may be that excel file saved on your thumb drive is in .xlsx format(Office 2007) which you are trying to open on a machine which doesnt have office 2007 rather it may have Office 2003 or lower vesion.
Check this and hope it helps !!
Awaiting response.
Thanks !
Sep 09, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Lexar JumpDrive Memory Stick Malfunction: ''format''msg now appears
Unfortunately, this is an occurring problem.
What I had to do was save all my files on my friend's computer, format the flash drive into NTFS and then throw the files back on.
It only takes a minute, but what a pain in the ****.
Good luck.
Jul 16, 2009 | Computers & Internet
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Feb 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
334 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
