Question about Kitchen Ranges
What is a f13 error code on a Frigidaire Gallery smooth top stove
Posted by danair2 on
Rakesh Kumar
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 35 Answers
Hi danair2,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Posted on Oct 22, 2009
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Mar 06, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
F13 code on frigidaire stove gas
Disconnect power, wait 30 seconds and reapply power. If fault returns uponpower-up, replace EOC
Jul 28, 2012 | Frigidaire Kitchen Ranges
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
Regards
R.K.
Oct 22, 2009 | Frigidaire PLES399EC Electric Kitchen...
Model FGFL87DSG error code F13
hi there,
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
let me know if this helps.
Oct 12, 2008 | Frigidaire Kitchen Ranges
Frigidaire CPL-EF398DCK
If unplugging doesn't reset it, then EOC electronic oven control is most likely defective
Nov 15, 2017 | Frigidaire fes365e Electric Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
854 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Kitchen Range Expert? Answer questions, earn points and help others
