Ryobi 540A need manual. Saw runs slow/ chain too tight? Had for 2 years, not used, lost book, didn't want to harm saw, or have to change blade without instructions. Lost charger. Just bought new charger would like to use saw.
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Loosen the bolts for the bar on the chain casing. Should be an adjustment screw either on the side of the chain casing or the inside front of the bar. Loosen screw and lift chain, chain drivers shouldn't lift past the bar grove .
Hope this helps you out.
Testimonial: "I will try tommorrow. Thanks so much"
