Is there a row of electrical contacts inside the camera's film chamber where the film canister goes? If so, then the camera automatically reads the ASA or ISO value from bare metal areas on the outside of the film canister.
Cannot see where you included the camera name nor model. Still, many film SLR have do not have a way to set the ASA, it reads the film cartridge, DX Code, that tells the camera the ASA to use.
I assume that this is a film camera that has light meter. It could be that the camera is set to a different film sensitivity than the actual film. For example, the film is 400 ASA but the camera is set to 100 ASA. The sensitivity rating of the film is written on the film box and on the film cartridge. Make sure you set the film ASA number on the camera too.
If the film has the DX coding on the can then the camera automatically sets the film speed. If the can is not coded then the camera automatically sets the ASA/ISO to 100, and there is no way to override this. If you need a manual, you may download one here.
Actually, it's called "ISO" on a digital camera. "ASA" refers to film speed. Anyway, if there isn't a button marked ISO, then you should be able to find it in the camera menu.
That can be a problem. The ASA dial has a post that links to another ring under the top cover. The ring under the cover is spring loaded via a tungsten cable that travels the span of the top of the camera to the rewind side. If you are not careful, the cable could break.
To get to the dial, unscrew the cap screw that holds the film advance lever on. The cap screw has 2 small holes for a specific tool, but small needle nose pliers with fine points will work. The lever can be removed with 2 washers along with it. You can now see the retaining nut for the dial. It is best to set the dial at 'B', 3200 ASA. Use the same pliers to remove the nut. The dial can be removed at this point. Best to lift it on the far side near the edge of the top. If the dial itself is damaged, I probably have a good used one. The ring under the top has a notch for the ASA dial post, at rest it should be at about 10:00 oclock. With the ASA dial still set at B/3200, lean the post into the notch and slowly turn it counter-clockwise till the ASA dial can be seated fully. Reassemble the other parts in the reverse order.
if it does not support manual ASA/ISO selection than you can just easely set it to under exposure( 1F stop) and afterwards just develop it as a 800ASA film.
Say you're using ASA/ISO 100 film:
Photos come out overexposed and you were shooting in A or S or P modes.
Just set your ASA/ISO to 200: this will gives one stop less and images will be correct.
