Question about Hisense Televison & Video
Unable to connect Hisense 65K390PAD to internet because, "Unfortunately, settings has stopped". Any suggestions?
Posted by Cindy Burt on
Franco Dosil
    Top Expert:
  • Hisense Master
  • 10,535 Answers
Hi Cindy, unplug the TV for 10 minutes and try again
If you do not succeed, reset the TV to Factory Settings
I send you the link to download your Hisense manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Cindy, desenchufa el televisor por 10 minutos e intenta nuevamente
Si no lo logras, resetea a Ajustes de Fabrica el televisor
Te envio el link para que descargues el manual de tu Hisense
Espero puedas solucionar el problema
Saludos Franco Dosil
https://etcpg3uvcgs41q4ci23mfssr-wpengine.netdna-ssl.com/wp-content/uploads/2015/11/65K390PAD_aus_m_en_man.pdf
https://etcpg3uvcgs41q4ci23mfssr-wpengine.netdna-ssl.com/wp-content/uploads/2015/11/65K390PAD_aus_m_en_qspg.pdf
Posted on Aug 05, 2019
1 Related Answer
gopakumarg43
  • 76407 Answers
SOURCE: Hisense remote control overheats and doesn't work. Hisense TV model is 65K390PAD. It's the original remote that come in the box bought Brand New.
REMOTE CONTROL HANDSET OVERHEATS???????????
What are you saying?
Are you MAD?
Posted on Mar 25, 2016
I have a hisense tv 32” how do I connect to wireless wifi
This would depend on the model and whether it was a SMART TV.
The internet connection is via a LAN cable or via your satellite or cable box to your Home Network. Your smartphone connect to wifi and via that to the television.
Feb 05, 2018 | Hisense Televison & Video
We went from cable tv to a dish. which changed our internet service. I am unable to change the service on our Hisense TV
You have to reset the set electronics to erase all prior settings. Look for reset button on unit or contact Hsense. Also, in the settings area for internet there may be an area for a totally new network.
Sep 22, 2017 | Hisense Televison & Video
My 50" hisense smart tv says I'm connected to the internet but when I try to use a app it says there is no internet connection
Don't know that much about Hisense but other brands when you connect to your modem you will have to pair the tv and it up with your wep password. Tv should ask you all of this in set-up screen.
Apr 02, 2017 | Hisense Televison & Video
I have a Hisense Smart TV model 60K390PA. I am connected to my wifi but it says i am not connected to the internet. What can I do. Thank you.
You should set it for net. If you wish to get more details visit the site linked here. http://homenol.blohspot.com/
Feb 25, 2017 | Hisense Televison & Video
48" HISENSE SMART TV 2014 /I HAVE NO WIRELESS INTERNET CONNECTION ANYMORE
Check out your manual and look for the section regarding connecting to your home network. The tv set must detect the network for it to properly set up the connection after you give it the name and password to your account.. Check for the network working properly with your laptop or other device(s). If those units connect then the problem has to be with the wireless circuits of your tv.
Can also try resetting the set to factory condition and starting anew with the setup procedure. Also unplug the set while it is on - then while unplugged press in the "on" button on set for about thirty seconds. Then replug set and try again.
Mar 06, 2016 | Hisense Televison & Video
How to set up forutube
Recommend using the installation and setup procedures straight from the manual. Unfortunately, I cannot access the manual, but I recently set up a new Smart TV and found that the manual is essential to making it easy and painless. The added benefit was that I learned how to properly use my TV easily.
Good luck,
Mar 02, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Televison & Video Logo
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
