LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
Posted on Aug 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
42" LG Plasma went dark
Sound is fine, picture is grainy and very dark hard to make out any picture
CoppellTVRepair.com
Level 3:
  • LG Master 778 Answers
  • Posted on May 06, 2011
CoppellTVRepair.com
LG Master
Level 3:
Answers
778
Questions
0
Helped
396385
Points
1847
It is not maybe, it is nearly 100% sure that the ZSUS board has failed and needs to be replaced.
When YSUS fails you typically get two possible outcomes: dark screen or flashing screen.
That's if the TV powers on at all.
In some cases it may short and of the fuse doesn't blow then the TV will refuse to power on from there on as the power board will be detecting the short and shut down.
When ZSUS fails you may get the same or, if the TV powers on, you'd typically get very very dark and grainy image.
Sometimes you may also get completely dark screen. That makes it hard to distinguish from a bad YSUS board and you end up having to rely on heat sinks temperature after 5-10 minutes of work and/or blown fuses (when each sustain has its own fuses).
See our site for more help on that.
www.coppelltvrepair.com
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Aug 14, 2009
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217393
Points
1225
Maybe z board bad need replaced
1helpful
2helpful
2answers
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
1helpful
2answers
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
2answers
LG 42" Plasma - Sound but no picture
HI,
I'll think that either your backlight or de backlight -driver, -supply is not OK.
Kind regards,
Gerard
2helpful
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
367helpful
34answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
ysus pcb that supplies voltage to the panel is faulty
1helpful
sounds like it may be a software upgrade
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
